FS civic parts and crv parts FS civic parts and crv parts USED SPOON lightweight 4.2KG FLYWHEEL for B-series $200 USED EXEDY Stage 1 Organic Clutch Kit for B-series, USED FOR 5000KM $250**********SOLD********** USED MSD 8.5MM SUPER CONDUCTOR SPARK PLUG WIRE FOR 99-00 CIVIC SIR $30 USED UNORTHODOX RACING UNDERDRIVE PULLEY FOR B-SERIES ENGINE $20 NEW UNORTHODOX RACING STANDARD SIZE LIGHTWEIGHT PULLEY FOR 1990-01 INTEGRA, 94-97 DELSOL DOHC, 99-00 CIVIC SIR DOHC ENGINE. *********SOLD******** NEW VALVE GUIDE SET FOR B-SERIES ENGINE. $80 NEW JFBK BRAKE SHOE SET FOR 97-00 CRV $25 NEW OEM AC FILTER FOR 97-00 CRV $30 USED OEM RADIATOR WITH CAP AND HOSE FOR 99-00 CIVIC SIR $60 USED OEM FRONT(20MM) AND REAR ROTOR(8.52MM) FOR 99-00 CIVIC SIR $10 EACH. OR $30 FOR SET***SOLD*********** USED HAWK HPS FRONT PAD(70%) FOR 99-00 CIVIC SIR $15************SOLD USED OEM REAR PAD (70%) FOR 99-00 CIVIC SIR $10*****************SOLD USED OEM REAR SHOCK AND SPRING FROM 00 SIR, WILL FIT ALL 96-00 CIVIC, USED FOR ABOUT 10,000 KM $80 FOR BOTH USED OEM 99-00 CIVIC SIR CAMS $120 USED OEM FRONT TOWER BAR FOR 96-00 CIVIC $30 USED OEM 99-00 SIR CIVIC HEADER $50 USED OEM DOHC VALVE COVER (CUT) $30 USED OEM CAM GEAR SET $30 USED 195/50/14 FALKEN ZIEX 512 TIRES SET OF 4 1 HAVE CAMBER WEAR,(50-70%)TREAD. 2 WITH 4X100 WHEEL. $80***********SOLD********** USED 00 CIVIC SIR 1.6L DOHC CYLINDER BLOCK 90,000KM $450. vin#1HGEM1159Y1310958 PLEASE PM me for pics and your email address. thanks |
do you have a set of OEM SiR wheels? |
USED OEM RADIATOR WITH CAP AND HOSE FOR 99-00 CIVIC SIR $60 dibs pm'd |
cheap cheap anyone?? |
bump for u |
| All times are GMT -8. The time now is 01:00 PM. |
