-   USED Automotive Performance Parts ONLY (https://www.revscene.net/forums/used-automotive-performance-parts-only_23/)
-   -   FS: 240SX turbo kit, brakes, & body kit (https://www.revscene.net/forums/573603-fs-240sx-turbo-kit-brakes-body-kit.html)
fukkeneh240 04-26-2009 01:21 AM
Hi,
All for a S13 DOHC KA. everything is on the car, but the car is jacked up and ready for stripping.
Turbo Kit (minus the electronics and FMIC kit). it's still on the car but seeing if there is any interest. Pretty much a t25 set up but will need a new t25 turbo, but will come with everything to turbo your car. you will only need to tap your own oil pan - $700
SS bottom mount Mani
T25 turbo (works but blows oil)
turbo air inlet pipe (connects to air filter)
oil feed
turbo elbow
down pipe
coolant lines
sr injectors
*** what you will need on your own are colder spark plugs (cheap), more efficient fuel pump (walboro i guess) and fuel filter (also cheap) while you're at it. ***
FMIC kit - 2.5 inch piping with 3 x 6 x 24 fmic, comes with all the couplings and clamps, hot pipe with BOV - $350
Turbo electronics:
SAFC 2 already programmed for this kit - $250
NGK air/fuel display - it's a wide band with sensor - $150
Z32 Air fuel meter (N62 MAF) - $150
Gauges - Boost, water temp, and oil pressure. comes with sensors - $100
3" exhaust with hi flow cat with magnaflow exhaust - $250
BUT if you want EVERYTHING above - $1500
That's it for now.
PM me
fukkeneh240 04-29-2009 08:21 PM
bump.
this is what is off the car as of today 29 apr 2009
FMIC kit
coilovers
Canadian OEM body kit
front z32 brake set up including z32 BMC.
turbo kit and electronics are coming off in the next few days.
i would prefer to sell the turbo kit as a whole, so i wont be parting the kit as of now.
fukkeneh240 04-30-2009 08:27 PM
edit.... 30 Apr 2009
turbo kit is off... well except the injectors but easy to take out.
xhenryma 05-01-2009 04:32 PM
can you send some pic of the 3" exhaust what brand is it? xhenryma@hotmail.com
fukkeneh240 05-01-2009 07:38 PM
exhaust is pending
injectors are out... so full turbo kit ready for a new home.
fukkeneh240 05-02-2009 01:51 PM
deposit left on entire turbo kit, fmic, and electronics.
everything else is still up for sale.
edit... Turbo kit, FMIC, electronics/gauges are gone.
made_bucky 05-04-2009 12:20 AM
thanks for the exhaust !!
fukkeneh240 05-04-2009 07:24 AM
hope it works for you.. exhaust is gone.. haha.
please delete this thread now.
