-   USED Automotive Performance Parts ONLY (https://www.revscene.net/forums/used-automotive-performance-parts-only_23/)
-   -   FS: B, D series parts. Cleaning up after a built. (https://www.revscene.net/forums/598861-fs-b-d-series-parts-cleaning-up-after-built.html)
trequartista_10 12-06-2009 09:31 PM
Up for sell, some stuff of DC and EG.
1. 1995 GSR side rubber mount (part of AC bracket and Tranny mount) $5@ side
2. 1995 GSR Charcoal canister $5
4. DA 15/16" master cylinder, will work with any B-series brake booster except the one from ABS and will work on EG without reflaring and rebent the brake line, $40
6. BNIB OEM Honda Throwout bearing for B-series hydro tranny $50.
7. BNIB OEM Honda clutch disc for 97-01 GSR and Type-R, $150 (But I think it should fit 94-01 Integra)
I would do $180 if you buy the clutch too, and I will give clutch aligning tool for free.
9. 1995 GSR standard size pistons with rods and bearings and cleaned already, $150 for all 4 of them, nothing wrong with them,i just upgrade mine with JDM Type-R
http://img24.imageshack.us/img24/5514/imgp2430.th.jpg
http://img18.imageshack.us/img18/9672/imgp2429b.th.jpg
http://img40.imageshack.us/img40/1006/imgp2428.th.jpg
10. 1995 GSR stock header with heat shield, $50
13. 2 B-series VTEC valve cover, both of them are cut 1 is chrome and the other one is painted red on the lettering and polished on the rest of the area, $100 each.
http://img5.imageshack.us/img5/9996/imgp2083k.th.jpg
http://img18.imageshack.us/img18/666/imgp2424s.th.jpg
http://img24.imageshack.us/img24/6215/imgp2423a.th.jpg
14. 1993 Civic Si brake booster and 13/16" master cylinder, $30@. Got 2 sets of them.
http://img36.imageshack.us/img36/6746/dscn1875b.th.jpg
19, B20A valve cover, $10
http://img36.imageshack.us/img36/6250/dscn1866.th.jpg
Parts added:
2. Various mounts and bracket off EG and DC, $5 @
http://img40.imageshack.us/img40/3022/imgp2416x.th.jpg
3. 1993 EG front brake calipers, works perfect, $20 a pair
http://img14.imageshack.us/img14/6743/imgp2417h.th.jpg
Thats all for now, I cant think about anything else, but will be more.
Will update more picture later on.
Thanks.
:burn::burn::burn:
Sold List:
17. 89-91 civic ignition lock with keys, $20
11. 1995 GSR 22T water pump, excellent condition, pic of it compare with the new one
12. 1995 GSR oil pump, excellent condition, pic of it compare with the new one
trequartista_10 07-24-2010 02:43 PM
UP
