01 Prelude power door lock problem The driver side door lock needs two tries (key or inside power switch) to open/close fully. Each try moves it halfway. When I manually move the switch, it's really stiff. Anyone know where the problem is? Seems to be ok when the weather is warmer. |
take off the inner door panel and lube all the related lock parts. |
^ this. if you decide you want to replace the part, get OEM. don't cheap out on the aftermarket crap. :) |
your power door lock motor is slowly dying. soon you will need a new one |
pull open the door lube up all the moving lock parts and that will buy you some time on parts replacement |
| All times are GMT -8. The time now is 10:41 PM. |
