-   USED Automotive Performance Parts ONLY (https://www.revscene.net/forums/used-automotive-performance-parts-only_23/)
-   -   WTB: B Series Engine Parts! (https://www.revscene.net/forums/627688-wtb-b-series-engine-parts.html)
jeem2 10-15-2010 07:50 PM
  1. Windage tray from B18C, C1 or C5
  2. Rear main seal cover (not the seal but metal part) from any B engine*
  3. Crank pulley (shorter one with 2 spots not 3) Any B engine
  4. Crank pulley bolt (any B engine)
  5. OBD2 lower timing cover (any OBD2 B engine)
  6. Tranny dust sheild (B series)
  7. Timing belt guide (that round ring that goes behind the crank pulley)
  8. Dual valve springs (just need 8 for exhaust side)
  9. Engine/Tranny stiffeners (brackets that bolt to the trans and engine near the oil pan)
And some other parts that i will order new, but figure id see if anyone has some un-used ones kicking around.
  1. Timing cover gasket
  2. Cam seal (cap)
jeem2 10-18-2010 05:44 PM
TTT!!
B18C1_T 10-20-2010 05:12 PM
i proly got most out of the items on your list if you like give me a call 778-882-2535 Ricky
