FS: obd0-obd1 conversion parts stuff i have sitting around -p06 ecu with a chrome chip ( GSR base map ) $100 -USED obd2 vtec dizzy $100 OBO -USED obd0-obd1 zerg industries jumper harness with the extra wires extended and solder to its places( vtec sol/ vtec pressure/ oem 4 wire o2 sensor conector) will come with obd1 4wire o2 sensor and obd0-obd2 dizzy jumper $120 everything you would need to do a LSVTEC/ GSR/TYPR in your obd0 honda/acura if you buy all 3 - $300 |
| All times are GMT -8. The time now is 07:55 PM. |
