Maintenance, Engine & Driveline Tech This forum is brought to you by The Speed Syndicate (TSS) in Burnaby. Discussion of maintaining your engine, transmission, differentails, rear ends, and mods associated with "driveline" parts..  |  |
03-29-2011, 04:13 PM
#1 | | My homepage has been set to RS
Failed 170 Times in 63 Posts
| noise from power steering unit, need flush or new unit
problem was diagnosed wrong by my machanic, its water pump...thanks
03-29-2011, 05:11 PM
#2 | | RS controls my life!
what "honda" is it? don't bother flushing it until you get the leak fixed. P/S fluid can't be burned up like engine oil. If its down, it leaks
__________________ Don't open your hood to strangers........ N 'ouvrez pas votre capot à des inconnus |
03-29-2011, 10:38 PM
#3 | | My homepage has been set to RS
tsx, but never saw any leaks, and now that its topped up.reservoir still shows full a couple of days later
03-30-2011, 11:58 AM
#4 | | Proud to be called a RS Regular!
Failed 5 Times in 1 Post
look harder, there has got to be a leak somewhere. PS steering fluid doesn't just disappear. As for the noise, top it off, lift both front wheels off the ground and bleed the air out of the system. If the noise stops then search for leaks.
03-30-2011, 01:29 PM
#5 | | I contribute to threads in the offtopic forum
grinding sounds could be an indication of bad bearings in the pump
__________________ Rise Auto Salon
I can be reached VIA text @ 778-232-1465 Oil change special $70 5 liters synthetic oil including OEM filter Fender rolling from $45 per fender Car Audio:
General Maintenance |
03-30-2011, 04:47 PM
#6 | | RS controls my life!
probably in the steering rack, fluid leaks out the rack end seals, but the dust boots hold in the fluid so the fluid doesn't hit the ground. If you're going to crawl under the car poke the boots with a small pick and see if any fluid leaks out of them.
Make sure the fluid you're using is Honda's stuff or at least honda compatable. Bleed the system by turning the wheels all the way left and right a few times. shouldn't need to lift the front wheels off the ground to do this
03-30-2011, 05:54 PM
#7 | | Head of HR....have a seat on that couch
Originally Posted by Puck Luck Bleed the system by turning the wheels all the way left and right a few times. | Did you do this?
__________________ feedback Originally posted by v.b. can we stop, my pussy hurts... Originally posted by asian_XL fliptuner, I am gonna grab ur dick and pee in your face, then rub shit all over my face...:lol Originally posted by Fei-Ji haha i can taste the cum in my mouth Originally posted by FastAnna when I was 13 I wanted to be a video hoe so bad RSUV #7 |
03-30-2011, 07:36 PM
#8 | | My homepage has been set to RS
Originally Posted by fliptuner Did you do this? |
haven't had the time, will try this weekend. appreciate all the feedback
03-30-2011, 07:55 PM
#9 | | Head of HR....have a seat on that couch
No need to wait. When you get home from work tomorrow (car warm), just crack the PS reservoir open a bit so air can escape, crank the steering wheel (steady speed), lock to lock, 3 or 4 times, check the fluid level and it should be fully bled.
Should take all of 5 minutes.
03-31-2011, 10:51 AM
#10 | | My homepage has been set to RS
ill do that tonite flip, im trying not to drive ,instead took the bike today, just to add this is happening even when i start the car (without moving). think might the bearings.
ill keep you posted. thanks |
04-10-2011, 12:05 PM
#11 | | My homepage has been set to RS
update. so my mechanic who diagnosed power steering issue was an idiot. as i mentioned. thr was no leak so doesnt make sense the fluid will be low. Turns out, it wsn't low, it was between minimum and maximum line (in the winter- its around minimum line) and he filled it up almost to the cap.
this machanic specialises in acura/honda engines. used a stetisscope also but still diagnosed it wrong. im glad i got a second openion before doing anything drastic.
i took it to another place. and turns out its my water pump. they used stethoscope and i heard the nose for myself. Noise was not coming from power steering unit.
04-10-2011, 12:09 PM
#12 | | Head of HR....have a seat on that couch
At least you know what it is. Unfortunately, since it's a waterpump, you're going to want to address it asap.
Water pump seizes, timing belt snaps = bent valves and maybe a cracked piston.
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -8. The time now is 02:34 AM. |
