Go Back   REVscene Automotive Forum > Technical Discussion > Suspension, Brakes , Wheels & Tires Tech
Suspension, Brakes , Wheels & Tires Tech THIS SPACE OPEN FOR ADVERTISEMENT. YOU SHOULD BE ADVERTISING HERE!
Suspension components, brakes, Wheels and Tires. All things related to how your car handles...
Old 05-12-2011, 10:24 PM   #1
SpartanAir's Avatar
Failed 298 Times in 88 Posts
Hub ring a tiny bit too small...will it cause problems?
I want to try to fit wheels from a Scion TC on to my Subaru Legacy. The bolt pattern is the same, the offset will work ok...but when I did more research I found that the Scion wheels are 54.1mm hub ring and the Subaru is 56.1mm. Other than test fitting them to be sure, is this totally impossible to make them fit, if the hub ring is 2mm larger on my subaru?
Also, the OEM Hex size on the Scion is 21mm, and the Subaru is 19mm. I figure the smaller lugs should hold the wheel on just fine...but it's the hub ring that is my concern.
Any help is appreciated! Thanks!
1994 Honda CB1000, Black
Previous Rides:
1986 Porsche 944, Black
Old 05-12-2011, 10:38 PM   #2
Jgresch's Avatar
Failed 207 Times in 86 Posts
Won't fit unless you make the hole bigger
Jgresch is offline   Reply With Quote
Old 05-13-2011, 07:31 AM   #3
F**K YOUR HEAD
ilvtofu's Avatar
Failed 643 Times in 181 Posts
If you think it's worth it you can bring it to a wheel shop to machine that 2mm. IIRC I got a quote for around $200 for a set of 4 from panthers but don't quote me on that. But I think it's safe to say that it wouldn't be worth it for some average looking wheels/fitment
Miata
Fiesta
