FS: B Series parts, 98 Spec long block/ ITR transmission, + more K&N RU2820 Filter - Flange Inside Diameter: 3 in (76 mm): $40 AEM Filter from B18C5 C/A Intake system - Flange I/D 3 in (76 mm) NOT dryflow: $10 vtec solenoid gasket (new) part#: 15825-P08-005: $20 ITR throttle body (no TPS): $70 Greddy Catch Can: $70 (4) O/S (+.25) OE JDM ITR pistons on ITR rods with ARP rod bolts* - $120 * Machine shop drilled one of the rods slightly off centre axis. Rod cap on this one rod needs to be lightly taped with a mallet to mount. Only realized this when bottom end was disassembled for subsequent build. Ran without issues for 30k KM. *approved by orgasm_donor* |
you have PM |
You have a PM Thanks, Jared |
Pm'd Posted via RS Mobile |
pm'd |
bumppen for a reply :) or a phone number to contact u |
Have a friend interested in the longblock. He is from Idaho so if you don't want to ship I can buy it for him. I will need some more info on it though. Could you pm me? Not sure if you had any compression numbers prior to removal and maybe the est~ milage after rebuild (is it 30k)? Thanks |
PM replied |
If only they made an H2B for a prelude chassis, i'd be all over that itr tranny. you still owe me $10 :devil: |
:whistle: My bad. Sorry for the wait and thanks for the ride along. I want ITBs now :) |
| All times are GMT -8. The time now is 05:55 AM. |
