-   USED Automotive Performance Parts ONLY (https://www.revscene.net/forums/used-automotive-performance-parts-only_23/)
-   -   [BNW] FS: NA Miata Timing Belt Kit + Water Pump + Accessory Belt (https://www.revscene.net/forums/678277-na-miata-timing-belt-kit-water-pump-accessory-belt.html)
Nintensity 12-23-2012 05:51 PM
Hey guys!
I'm selling my BRAND NEW Miata Timing Belt Kit, Water Pump, and AC belt with Power Steering for the NA 1994-1997 Miatas. You can use the kit for your 1990-1993 Miatas, but you have to buy the Front Crankshaft Seal for your model years, as its different than the 94-97 ones.
I bought the kit from Flyin Miata almost a year ago and sold my Miata before I even did the Timing Belt. It's been sitting in the box.
The only thing that is not included in the Timing Belt Kit is the valve cover gasket, so you'll have to get one from Lordco.
Also, I bought the Water Pump and the Accessory Belt, simply because it's a necessary maintenance fix when you're already doing the Timing Belt change.
Timing Belt Kit:
Flyin' Miata : Miscellaneous : Maintenance parts : Timing belt kit
Water Pump:
Flyin' Miata : Miscellaneous : Maintenance parts : Water pump
Accessory Belt: AC with Power Steering:
Flyin' Miata : Miscellaneous : Maintenance parts : Accessory belt, AC and PS
Kit is $160 (before I payed for shipping) ,I'll sell it for $140 FIRM.
Water Pump is 70, i'll sell it for $60 FIRM.
Accessory Belt: AC with Power Steering, i'll sell it for $10 FIRM.
If you buy everything, which I recommend you doing, since Water Pump and Accessory belt can be done during the process, I'll sell it for $210 FIRM. The Timing Belt Kits in Canada easily go for $350. This is already a good price since I payed for shipping and it's been sitting around for the LONGEST time.
Text 778-388-3135 for the fastest response!
Nick
PICTURES: FS: NA Miata Timing Belt Kit + Water Pump + Accessory Belt
Nintensity 01-19-2013 03:34 PM
BUMP!!!
Nintensity 01-26-2013 06:36 PM
Bump!
