Used body kits, Bumpers, spoilers, side skirts, grills, PIAAs, HID kits, Clear Corners... |  |
01-22-2013, 11:44 PM
#1 | | I *Fwap* *Fwap* *Fwap* to RS
Failed 10 Times in 6 Posts
| FS: BNIB JDM SARD Pro EL Oil/Water Temp, Oil Press + BILLION Water Temp Gauges
I have a set of gauges that I've been keeping aside for my car, that were supposed to be installed on my first project car (but never happened), and then the Lude, which never happened as well!
First up, I have a pair of Brand New In Box, 60mm SARD Pro EL Oil Pressure & Oil/Water Temp gauges! I believe these have been discontinued now..Bought these a few years back, and never ended up installing them
Each gauge comes with everything you need in the box (Sensor, Wiring Harness & Plugs, Instructions). SOLD
Secondly, I have a used JDM 70mm BILLION VFC Max Twin Meter Digital Gauge! This one is actually a pretty cool one..Not only will it display coolant temp, you could also use it as a fan switch! Instead of using a lower temp fan switch, you could simply wire this into the radiator fan control module, and you could set the temp that the radiator fan would switch on at any temp you like!
The second digital indicator could also display other things, such as voltage, etc..You could actually control two fans with this unit, and it also has a few warning indicator in case the temp shoots past the threshold (Which you could also set at any temp you'd like!)
Overall, it's just a cool unit  Well-built as well! Glass Cover, with aluminum body! It comes with everything you see in the pics (Wiring Harness, Instruction, Gauge Stand). It doesn't come with a sensor, but you could use pretty much any third party temp sensor that reads from 0-150 degree Celsius!
Asking $220 --> $180 for this unit.
Feel free to PM me or email at nsxr_onald@hotmail.com if anyone's interested. Thanks for looking!
02-12-2013, 01:40 PM
#2 | | I *Fwap* *Fwap* *Fwap* to RS
TTT
02-15-2013, 12:08 PM
#3 | | I *Fwap* *Fwap* *Fwap* to RS
TTT
PMs replied.
02-28-2013, 01:00 PM
#4 | | I *Fwap* *Fwap* *Fwap* to RS
BUMP
Price lowered..
03-15-2013, 10:31 PM
#5 | | I *Fwap* *Fwap* *Fwap* to RS
TTT
04-15-2013, 10:55 PM
#6 | | I *Fwap* *Fwap* *Fwap* to RS
TTT
Still available!
05-18-2013, 12:52 AM
#7 | | I *Fwap* *Fwap* *Fwap* to RS
BUMP
06-01-2013, 09:21 AM
#8 | | I *Fwap* *Fwap* *Fwap* to RS
Saturday Morning BUMP
06-21-2013, 12:21 AM
#9 | | I *Fwap* *Fwap* *Fwap* to RS
TTT
Still available, price is not set in stone.
06-29-2013, 12:32 AM
#10 | | I *Fwap* *Fwap* *Fwap* to RS
BUMP
09-02-2013, 10:21 PM
#11 | | I *Fwap* *Fwap* *Fwap* to RS
TTT
09-24-2013, 05:12 PM
#12 | | I *Fwap* *Fwap* *Fwap* to RS
BUMP
Price lowered.
These are great units, and comes with everything you need to install!
Someone take these off my hands, please!
TTT
10-04-2013, 05:56 PM
#13 | | I *Fwap* *Fwap* *Fwap* to RS
TTT
10-28-2013, 12:37 AM
#14 | | I *Fwap* *Fwap* *Fwap* to RS
TTT
11-16-2013, 10:59 AM
#15 | | I *Fwap* *Fwap* *Fwap* to RS
TTT
Price is OBO |
11-26-2013, 07:39 AM
#16 | | I *Fwap* *Fwap* *Fwap* to RS
TTT
12-17-2013, 11:15 AM
#17 | | I *Fwap* *Fwap* *Fwap* to RS
TTT
12-21-2013, 11:15 AM
#18 | | I *Fwap* *Fwap* *Fwap* to RS
BUMP
01-04-2014, 01:35 AM
#19 | | I *Fwap* *Fwap* *Fwap* to RS
TTT
01-10-2014, 12:19 AM
#20 | | I *Fwap* *Fwap* *Fwap* to RS
TTT
01-31-2014, 10:03 PM
#21 | | I *Fwap* *Fwap* *Fwap* to RS
TTT
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -8. The time now is 07:36 PM. |
