-   Maintenance, Engine & Driveline Tech (https://www.revscene.net/forums/maintenance-engine-driveline-tech_190/)
-   -   2006 Hyundai Accent P0450 Engine Code help fixing (https://www.revscene.net/forums/691691-2006-hyundai-accent-p0450-engine-code-help-fixing.html)
Jas29 01-03-2014 03:34 PM
Hyundai P0450 OBD/DLC Error Code - Evaporative Emission System Pressure Sensor/Switch
Causes
Possible causes of OBD code P0450
- The EVAP control system pressure sensor circuit is open or shorted - Rubber hose to EVAP control system pressure is clogged, vent, kinked, disconnected or improper connection. - EVAP control system pressure sensor may be faulty - EVAP The Error code is generally activated on detection of the following conditions: - An improper voltage signal from EVAP control system pressure sensor is sent to ECM.
Possible Solutions
- Replaced EVAP Control System Pressure Sensor
Where is the Pressure sensor located even
!Tigger 01-03-2014 05:45 PM
gas tank beside the charcoal canister
