X-Star 27" DP2710LED 2560x1440 PLS 120hz LED LCD Monitor Up for sale is a used X-Star DP2710LED 27" monitor from Korea. Comes with HDMI cable and original power cord. There are only 4 buttons on the monitor, volume + (up), Volume - (Down), Brightness (Up) and Brightness (Down) The only flaws I realized recently is that all the buttons are not working but the monitor is working and the current brightness is good enough for day to day use. That's why I sell for so cheap. Asking for $ 150.00 firm. No return and No refund. Graphic Card Compatibility - It uses Bypass type board. Compatibility issue with Graphic card and Mainboards may occur. Please check the compatibility before purchase. Compatible : GT440 / GT450 / GT460 / GTX550TI / GTX560 / GTX560TI / GTX570 / GTX580 HD5450 / HD5550 / HD5670 / HD5830 / HD6570 / HD6750 / HD6770 / HD6870 / HD6950 / HD6970 / HD6990 NOT compatible : HD5570 / HD5750 / HD5770 / HD5850 / HD5870 / HD5970 Recommended graphic cards -NVIDIA: GTX460 or more than 1GB memory, with Dual Linked DVI-D port. -ATI: HD6850 or more than 1GB memory, with Dual Linked DVI-D port. Dual Monitor configuration recommended -GTX580 or HD6970. The GPU should have 2 Dual linked DVI port. -Please use DVI-D port only. Cannot be used with DVI-I or DVI-S. Brand : X-STAR Model : DP2710 LED Type : 27Inch (68.5cm) Panel : SAMSUNG PLS Screen Size : 596.74 x 335.66 mm Resolution : WQHD 2560 x 1440 Contrast : 1000 : 1 (DCR 50000:1) Luminosity : 300 cd/㎡ Pixel Pitch : 0.233 mm Viewing Angle : 178˚ (Up / Down / Left / Right) Color Display : 16.7 MP Back-light : LED Input : DVI (Dual Link) / Audio (In / Out) / Power Power : 45 W Standby Power : 0.5 W Size (Stand) : 646 x 462.96 x 57 mm Size (Stand X) : 646 x 399.8 x 57 mm <CONTENTS> Monitor DVI-D (Dual Link) Cable AU Power Cable Audio Cable |
| All times are GMT -8. The time now is 08:05 AM. |
