Old 04-17-2017, 04:28 PM   #1
smokinloc's Avatar
k20a3 swap and k swap parts
k20a3 complete motor + 5 speed trans out of a 2003 civic SiR EP3, complete motor / starter / alternator / re-wrapped engine harness, charge harness, OE plastic intake arm, has Brand new oil pan/gasket & crank pulley & water pump & OE ngk spark plugs, intake manifold completely cleaned with new intake & TB gaskets, Comes with BNIB valve cover gasket, has a freshly machined flywheel. comes with factory ECU - $1100 **** LOCATED IN STORAGE IN NANAIMO**** REST OF PARTS WITH ME IN SURREY ****
RSX type-S shifter box & cables - $200
K swap axles less then 500km on them, will fit ef/eg/ek/da/dc - $350
EF k swap Plug and Play engine to chassis conversion harness - $350
K-Tuned k swap 4-2-1 header for eg/ek/dc, can also fit ef/da if crossmember modified - $375
will sell all of it for $2000, will throw in the engine stand the motor is on as well
Was going to do a swap into my civic hatch but decided to go turbo instead, good for swaps into any civic or Integra, possibly trade for turbo parts or complete kit !!
best to email me for contact, I don't check my messages on here very often...
fallen_33@hotmail.com
2005 Acura TSX 6sp - Daily
smokinloc is offline   Reply With Quote
