-   USED Automotive Performance Parts ONLY (https://www.revscene.net/forums/used-automotive-performance-parts-only_23/)
-   -   [YVR] FS: Redtop SR20DET PART OUT S13/S14/240sx RARE PARTS (https://www.revscene.net/forums/713392-redtop-sr20det-part-out-s13-s14-240sx-rare-parts.html)
dustyco 09-20-2017 10:38 PM
If you are looking to pick up some high quality parts for you SR powered car, or you want to get in the game, this is the sale for you! The engine has good compression numbers but has a bit of blowby (at 15psi) and the intake cam is pitted. I've been running this engine for 2 years without any mechanical issues. I recently had it on the dyno with this set up on a very safe tune it made 280hp/270lbft at the wheels.
We can make a deal if you are interested in multiple items!
Willing to ship at buyers expense!
------See this album for pictures------
Redtop SR20 with Tomei Cams, Greddy oil pan, Greddy pulleys, PS Pump, and a brand new alternator - 1400
Splitfire Ignition System - 200
Tomei 555cc Injectors - 400
Greddy Intake Manifold (authentic) with big throttle body, IACV etc. - 500
4in Z32 MAF Air filter adapter - 15
Tomei Expreme Exhuast Manifold - 425
GT2860RS Disco Potato Turbo (Compressor: 0.60A/R, 47mm inducer. Turbine: 0.86A/R, 47mm exducer) with HKS Wastegate and all lines - 600
Tomei Turbo Elbow - 85
Greddy Turbo Inlet pipe - 65
Trust Downpipe (pretty beat up, but works well) - 80
Blitz SUS Power Core Stainless Steel Mesh Filter (fits Z32 MAF, can be adapted to anything) - 90
SR 5-Speed transmission - 200
B&M Short shifter - 200
Blitz Single Active Clutch/Flywheel (ORC replacement plates are still available) - 350
Clutch Slave with braided line - 40
DSS Steel one-piece Driveshaft (for ABS Diff) - 300
Almost new S14 manual Trans speed sensor - 90
Starter - 50
S14 Apexi N1 Coilovers FRONT ONLY - 400
240sx KA24DE S13/S14 Power Steering Pump - 60
