REVscene - The Northwest's #1 Sport Compact Car and Classifieds Site
Welcome to the Vancouver's Top Classifieds and Automotive Forum - REVscene.net forums.
Go Back   Vancouver's Top Classifieds and Automotive Forum - REVscene.net > Technical Discussion > Suspension, Brakes , Wheels & Tires Tech
Suspension, Brakes , Wheels & Tires Tech THIS SPACE OPEN FOR ADVERTISEMENT
Suspension components, brakes, Wheels and Tires. All things related to how your car handles...
LinkBack Thread Tools
Old 05-12-2011, 10:24 PM   #1
SpartanAir's Avatar
Failed 224 Times in 59 Posts
Hub ring a tiny bit too small...will it cause problems?
I want to try to fit wheels from a Scion TC on to my Subaru Legacy. The bolt pattern is the same, the offset will work ok...but when I did more research I found that the Scion wheels are 54.1mm hub ring and the Subaru is 56.1mm. Other than test fitting them to be sure, is this totally impossible to make them fit, if the hub ring is 2mm larger on my subaru?
Also, the OEM Hex size on the Scion is 21mm, and the Subaru is 19mm. I figure the smaller lugs should hold the wheel on just fine...but it's the hub ring that is my concern.
Any help is appreciated! Thanks!
2000 Subaru Legacy Wagon, Dark Green
1994 Honda CB1000, Black
Previous Rides:
1991 Mercedes Benz 300TE, Black
1990 Nissan Pathfinder SE-V6, Black
1981 Yamaha XS650 Special, Black
1986 Porsche 944, Black
SpartanAir is offline
Old 05-12-2011, 10:38 PM   #2
Jgresch's Avatar
Failed 197 Times in 76 Posts
Won't fit unless you make the hole bigger
Jgresch is online now
Old 05-13-2011, 07:31 AM   #3
YOU BETTUR REDNECKOGNIZE
ilvtofu's Avatar
Failed 578 Times in 168 Posts
If you think it's worth it you can bring it to a wheel shop to machine that 2mm. IIRC I got a quote for around $200 for a set of 4 from panthers but don't quote me on that. But I think it's safe to say that it wouldn't be worth it for some average looking wheels/fitment
Proud Member of GRAPE Great Revscene Action Photography Enthusiasts
XBL: ilvtofu92
(10-0-0) Buyer/Seller Rating
My 2000 Miata
My 1990 Miata SOLD!
FS: Canon 7D w/ 15-85mm Lens
FS: 4x100 Varrstoen V1/AD08
ilvtofu is offline
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
