-   USED Automotive Performance Parts ONLY (https://www.revscene.net/forums/used-automotive-performance-parts-only_23/)
-   -   fs; misc oem engine parts civics eg ek 92-00 (https://www.revscene.net/forums/509731-fs%3B-misc-oem-engine-parts-civics-eg-ek-92-00-a.html)
Sohc_turbo4 12-25-2007 02:28 PM
just list of stuff getting rid of
z6 valve cover 92-95 si. i painted this back in summer but never used it. i primed it and painted with sikkens base coat the color is from a g35 named emerald mist. it is a metallic green and clear coated with dupont clear. this is actual autobody paint so wasnt cheap. if you want the H and honda back to silver thats not a problem. sell for $30
http://img402.imageshack.us/img402/5604/p5111700p.jpg
OEM civic d series header off an 95 civic will fit all d series. 02 sensor is taken off.
10 bucks
http://imgcash1.imageshack.us/img218...9040155qn3.jpg
oem nissin brake booster/ master cylinder 13/16 works perfect 95 civic cx drums rear 20
http://img241.imageshack.us/img241/8...1214ap8.th.jpg
d16y7 intake manifold, fuel rail, regulator, all sensor mounts are good, and throttle body. 30
http://img210.imageshack.us/img210/1...1215qs8.th.jpg
http://img241.imageshack.us/img241/7...1218kr2.th.jpg
http://img241.imageshack.us/img241/6...1219gu4.th.jpg
d15 valve cover from 93 civic sedan black powdercoat
$10
http://img407.imageshack.us/img407/6744/pb022279op9.jpg
Sohc_turbo4 01-13-2008 02:18 AM
ttt
Sohc_turbo4 02-25-2008 07:08 PM
ttt
Sohc_turbo4 03-19-2008 07:21 PM
tttt
Sohc_turbo4 04-05-2008 11:34 PM
to the top
Sohc_turbo4 04-16-2008 10:33 PM
to the top
Sohc_turbo4 05-10-2008 03:09 PM
to the top
Sohc_turbo4 05-28-2008 09:00 PM
to the topss
RALLI 05-28-2008 09:20 PM
you selling the one beside the headers (lower control arm) how much thanx
Sohc_turbo4 05-29-2008 07:07 PM
sorry man sold those a while ago
Sohc_turbo4 06-23-2008 07:45 PM
to the top
Sohc_turbo4 08-07-2008 07:23 PM
to the top
Sohc_turbo4 09-03-2008 07:33 PM
to the top
Sohc_turbo4 11-11-2008 04:31 PM
to the top
Sohc_turbo4 11-16-2008 08:08 PM
to the top
Sohc_turbo4 11-29-2008 06:00 PM
to the top
Sohc_turbo4 12-08-2008 07:51 PM
to the top
Sohc_turbo4 01-18-2009 04:37 PM
to the top
Sohc_turbo4 01-30-2009 06:12 PM
ttt
Sohc_turbo4 03-31-2009 09:15 PM
ttt
hyek 04-05-2009 07:55 PM
pm'ed
buddy 04-09-2009 09:33 PM
just a question out of curiosity about the metallic green valve cover, can it withstands the extreme engine heat since you mentioned you used body paint ... and i have been told it requires special hi-temp paint ..
Sohc_turbo4 04-27-2009 07:27 PM
with the primer underneath it will be fine. the valve cover doesnt get that hot.
