Used Intakes, Exhausts, Cams, ECUs, trannys, Turbo kits, Intercoolers, Vafcs, Wastegates... |  |
12-25-2007, 02:28 PM
#1 | | I *Fwap* *Fwap* *Fwap* to RS
| fs; misc oem engine parts civics eg ek 92-00
just list of stuff getting rid of
z6 valve cover 92-95 si. i painted this back in summer but never used it. i primed it and painted with sikkens base coat the color is from a g35 named emerald mist. it is a metallic green and clear coated with dupont clear. this is actual autobody paint so wasnt cheap. if you want the H and honda back to silver thats not a problem. sell for $30
OEM civic d series header off an 95 civic will fit all d series. 02 sensor is taken off.
10 bucks
oem nissin brake booster/ master cylinder 13/16 works perfect 95 civic cx drums rear 20
d16y7 intake manifold, fuel rail, regulator, all sensor mounts are good, and throttle body. 30
d15 valve cover from 93 civic sedan black powdercoat
$10
01-13-2008, 02:18 AM
#2 | | I *Fwap* *Fwap* *Fwap* to RS
ttt
02-25-2008, 07:08 PM
#3 | | I *Fwap* *Fwap* *Fwap* to RS
ttt
03-19-2008, 07:21 PM
#4 | | I *Fwap* *Fwap* *Fwap* to RS
tttt
04-05-2008, 11:34 PM
#5 | | I *Fwap* *Fwap* *Fwap* to RS
to the top
04-16-2008, 10:33 PM
#6 | | I *Fwap* *Fwap* *Fwap* to RS
to the top
05-10-2008, 03:09 PM
#7 | | I *Fwap* *Fwap* *Fwap* to RS
to the top
05-28-2008, 09:00 PM
#8 | | I *Fwap* *Fwap* *Fwap* to RS
to the topss
05-28-2008, 09:20 PM
#9 | | What hasn't Killed me, has made me more tolerant of RS!
you selling the one beside the headers (lower control arm) how much thanx
05-29-2008, 07:07 PM
#10 | | I *Fwap* *Fwap* *Fwap* to RS
sorry man sold those a while ago
06-23-2008, 07:45 PM
#11 | | I *Fwap* *Fwap* *Fwap* to RS
to the top
08-07-2008, 07:23 PM
#12 | | I *Fwap* *Fwap* *Fwap* to RS
to the top
09-03-2008, 07:33 PM
#13 | | I *Fwap* *Fwap* *Fwap* to RS
to the top
11-11-2008, 04:31 PM
#14 | | I *Fwap* *Fwap* *Fwap* to RS
to the top
11-16-2008, 08:08 PM
#15 | | I *Fwap* *Fwap* *Fwap* to RS
to the top
11-29-2008, 06:00 PM
#16 | | I *Fwap* *Fwap* *Fwap* to RS
to the top
12-08-2008, 07:51 PM
#17 | | I *Fwap* *Fwap* *Fwap* to RS
to the top
01-18-2009, 04:37 PM
#18 | | I *Fwap* *Fwap* *Fwap* to RS
to the top
01-30-2009, 06:12 PM
#19 | | I *Fwap* *Fwap* *Fwap* to RS
ttt
03-31-2009, 09:15 PM
#20 | | I *Fwap* *Fwap* *Fwap* to RS
ttt
04-05-2009, 07:55 PM
#21 | | 14 dolla balla aint got nothing on me!
Failed 5 Times in 5 Posts
pm'ed
04-09-2009, 09:33 PM
#22 | | I *Fwap* *Fwap* *Fwap* to RS
Failed 121 Times in 27 Posts
just a question out of curiosity about the metallic green valve cover, can it withstands the extreme engine heat since you mentioned you used body paint ... and i have been told it requires special hi-temp paint ..
Q: What do you like most in a woman?
A: My dick Quote:
Originally Posted by JL9000 this is the internet and everyone knows better about what happened sitting behind a desk than the people who are actually involved. | |
04-27-2009, 07:27 PM
#23 | | I *Fwap* *Fwap* *Fwap* to RS
with the primer underneath it will be fine. the valve cover doesnt get that hot.
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -8. The time now is 07:08 PM. |
