Old 01-21-2009, 11:11 AM   #1
monkey_trouble's Avatar
car battery problem?
i drive a honda civic 06 coupe...yeah so having trouble starting my car...um car battery died total of 3 times from dec to jan..is it because of the cold??...and it is kinda slow when i start my car..not like a clean start but the engine kinda stutters?...is it time for a new battery or is there something else wrong?..i bought this car in august used from the dealership?...so its like only a 3 year car so what do you guys think
PM me or something thanks
Even if the morrow is barren of promises. Nothing shall forstall my return.
(\__/)
(")_(")
This is Bunny. Copy and past
bunny into yoursignature to help him gain world domination.
http://www.revscene.net/forums/monke...48#post6589248
monkey_trouble is offline   Reply With Quote
Old 01-21-2009, 01:36 PM   #2
Psykopathik's Avatar
Failed 83 Times in 30 Posts
alternator faulty. esp if battery dies a lot. under warranty?
My 100+ Buy and Sell feedback
Old 01-21-2009, 02:30 PM   #3
RS Veteran Mod
Super Dipper's Avatar
make sure the battery is charged or substitute with a known good battery. start car up and let it run for a bit, then disconnect the positive terminal from the battery. if the car dies there is an issue with the alternator, primarily with the voltage regulator.
if the car doesnt die, you have a bad power source(battery), but to be certain, take a volt meter to the battery and check voltage under a load situation.
Team 4 MotorSports
Island Speed Lab...+1
Speed is our business
88 CRX - Turbo AWD
03 G35- HKS GT Supercharged - Toy
03 Cummins 2500 - Tow Rig/ Money maker
Originally Posted by NashMan View Post
think befro you type
Super Dipper is offline   Reply With Quote
Old 01-21-2009, 02:43 PM   #4
MoD
k2_alpha's Avatar
Failed 124 Times in 20 Posts
and easy way to check if it is your battery is to start your car, boost it if neccessary, then just let your car run or drive your car around. if it does die it is probably your alternator not recharging your battery.
its a simple test that generally works if you know your battery is in good shape
k2_alpha is offline   Reply With Quote
Old 01-21-2009, 03:08 PM   #5
Did you have any electronics installed during that time or prior to that? It's also possible you have a parasitic draw somewhere.
Old 01-21-2009, 05:51 PM   #6
Puck Luck's Avatar
do you know if thats the original factory bttery?
While running it should be putting out 14.5 volts. You'll need a load tester to properly see how many amps the alternater is putting out. But ,not likely the alternater. Haven't seen any problems with these newer civics.
Like bcrdikes says, it could be a draw if you have any aftermarket accerories installed. Typicaly, your car should have about a 15 milli amp draw if its all stock
Don't open your hood to strangers........ N 'ouvrez pas votre capot à des inconnus
Puck Luck is offline   Reply With Quote
Old 01-21-2009, 11:48 PM   #7
i got a fujita intake install few months ago but didnt get any problems till late december
(\__/)
(")_(")
Old 01-22-2009, 03:05 AM   #8
NEWBIE ACCOUNT!
I thought intakes didn't use electricity.
NoMoreG35 is offline   Reply With Quote
