Old 03-28-2009, 10:39 AM   #1
aznsuperman's Avatar
Failed 314 Times in 38 Posts
How It's Made: Carbon Fibre Car Parts
http://watch.discoverychannel.ca/#clip140681
it's pretty cool~
aznsuperman is offline   Reply With Quote
Old 03-28-2009, 10:56 AM   #2
124Y's Avatar
Failed 192 Times in 41 Posts
Nice finding =]
Old 03-28-2009, 11:00 AM   #3
shenmecar's Avatar
Failed 530 Times in 136 Posts
indeed!
Old 03-28-2009, 11:15 AM   #4
!SG
OWNER/C.F.O./MONEYMAN
!SG's Avatar
Failed 6 Times in 3 Posts
hmm, i would say thats closer to "wet carbon" than dry carbon technique.
dry carbon uses an autoclave to cure the piece. its technically lighter and stronger. wet carbon uses the same type of technique but lets it cure and dry without the use of an autoclave. it weighs more but u dont need an expensive large autoclave. a lot of the parts u see available for cars out, like cf hoods, generally just use 1 layer of carbon fibre with a fibreglass backing. CF isnt cheap anymore, so they use the fibrglass for strength.
Ebisu VIP #001
Revscene.net Vendors
Old 03-28-2009, 11:21 AM   #5
truong's Avatar
Failed 165 Times in 29 Posts
alright, I have a FRP widebody kit, Lets make some CF parts
truong is offline   Reply With Quote
Old 03-28-2009, 11:27 AM   #6
!SG
!SG's Avatar
first you need to pick up the rolls of CF. highest quality CF ive seen so far is from japan. i dont know the current price for it though.
whatever part you have, u need to make a negative mold of it so that u can lay the CF over it to make a positive mold. most molds are good for 50 or so replica parts.
then u gotta make sure u get the right resin. there are so many different types out there. u got really strong ones but they are so strong, they are brittle. then u got the super soft ones, they are great cuz its closer to polyurethane, but flimsy. the ones in between, u gotta find one that doesnt turn yellow after a year of use.
as for labour, someone that can work with fibreglass can generally do it. the hardest part is making sure there are no air bubbles, hence why they used a vacuum, and rollers to push out as much air as possible. a vibrating table will help too.
after that, clear coat it, buff it, and there u go! CF PARTS!
Ebisu VIP #001
Old 03-29-2009, 06:13 PM   #7
Authorized RS.net Sponsor
perfect_g's Avatar
sweet
perfect_g is offline   Reply With Quote
Old 03-29-2009, 06:24 PM   #8
JSALES's Avatar
Failed 296 Times in 68 Posts
awesome, i think when i'm bored from now on i'm going to watch the discovery channel
Old 03-30-2009, 06:51 PM   #9
cool basketball court....
h8crime is offline   Reply With Quote
Old 03-30-2009, 08:11 PM   #10
Failed 730 Times in 91 Posts
that was a pretty nice basketball court
