-   -   problem using VGA cables to PC help please (https://www.revscene.net/forums/570313-problem-using-vga-cables-pc-help-please.html)
bobyu 03-31-2009 12:57 AM
whenever I switch from DVI to Vga by pressing the source button on my LG monitor, it would say analog power saving mode. I know this happens when the monitor does not detect output from PC. Does this have anything to do with my video card 8800GT? MAybe some type of driver update?
I wanted to use my VGA -> VGA again so I can use my HDMI - > DVI cables for my PS3 to PC monitor and switch between the 2.
anyone know how to fix this problem?
John 03-31-2009 01:44 AM
Does your 8800Gt have a VGA connector?
Hook up the VGA cable and do a cold boot.
DragonChi 03-31-2009 05:33 PM
i think he's doing vga from his monitor to dvi, since 8800gt only has dvi connectors.
bobyu 03-31-2009 08:49 PM
im even using the adapter vga to DVI so i can plug into 8800GT output again. but still says power sleeping mode after i hit the "source" button
DragonChi 04-01-2009 08:10 PM
Have you tried both the DVI outputs?
