Old 03-30-2009, 11:57 PM   #1
bobyu
Failed 5 Times in 3 Posts
problem using VGA cables to PC help please
whenever I switch from DVI to Vga by pressing the source button on my LG monitor, it would say analog power saving mode. I know this happens when the monitor does not detect output from PC. Does this have anything to do with my video card 8800GT? MAybe some type of driver update?
I wanted to use my VGA -> VGA again so I can use my HDMI - > DVI cables for my PS3 to PC monitor and switch between the 2.
anyone know how to fix this problem?
bobyu is offline   Reply With Quote
Old 03-31-2009, 12:44 AM   #2
John
Failed 10 Times in 6 Posts
Does your 8800Gt have a VGA connector?
Hook up the VGA cable and do a cold boot.
John is offline   Reply With Quote
Old 03-31-2009, 04:33 PM   #3
DragonChi
DragonChi's Avatar
Failed 40 Times in 26 Posts
i think he's doing vga from his monitor to dvi, since 8800gt only has dvi connectors.
DragonChi's BuySell rating
Old 03-31-2009, 07:49 PM   #4
bobyu
im even using the adapter vga to DVI so i can plug into 8800GT output again. but still says power sleeping mode after i hit the "source" button
Old 04-01-2009, 07:10 PM   #5
DragonChi
DragonChi's Avatar
Have you tried both the DVI outputs?
Forum Jump
