Go Back   REVscene Automotive Forum > Technical Discussion > Autobody, Lighting, & Structural Tech
Autobody, Lighting, & Structural Tech This forum is brought to you by RPM Electronics in Burnaby.
Discussion about modifying your auotomotive lighting, retrofits, auto body, share projects, ideas, etc.
Old 04-07-2009, 11:44 PM   #1
I am Hook'd on RS
matt_s's Avatar
Body Work Help
He guys so the other week I went out 4xing with a few buds and I hit a tree and dented the side of my box in. My problem is that its a double walled box so I can't push it out from the inside. I just want to pull as much of it out as i can I don't care if it doesn't look like new but I just want it to look better then it does. I have tried to use a Plunger but it couldn't create a suction to pull it out. Any ideas how to pull this one out? Here is a pic of the carnage...
http://i110.photobucket.com/albums/n...SideView-2.jpg
http://i110.photobucket.com/albums/n.../DentedCab.jpg
Also I am wanting to spray bomb the doors silver so they match the rest of the truck. After i wet sand the clear off of the doors should i primer the door or just spray the color? Again it doesn't need to look perfect just want it all one color. It is only a Bush Beater so.....
Thanks
Matt
matt_s is offline   Reply With Quote
Old 04-08-2009, 01:01 PM   #2
Failed 67 Times in 51 Posts
see if you can borrow a tip welder and pull hammer.. grind the bare metal. weld, then pull.
