Old 04-08-2009, 02:04 PM   #1
girlcrazy_420's Avatar
Failed 4 Times in 3 Posts
HELP! Mazda guys... engine isnt running right.
Its regarding a 1992 Mazda b2200 EFI 8v engine.
Once the engine is warmed up, the air/fuel meter goes to "LEAN" and about 5seconds later its running rough, sputtering out in a pulsating type condition. If I turn the ket off for a moment and back on, its good as new for another few minutes. The longer I turn the key off for, the longer/better it runs.
Here is what I have replaced due to the problem. maf, fuel pump, fuel filter, fpr, computer, coil pack, coil resistors, misc fuzes and relays and i'm sure I missed a few other things.
Ideas?? I dont get a CEL...
LADIES!!! Tired of being alone? Going through too many batteries at bedtime? Would you like a "hand"?? Well, you're in luck!!! S.T.U.D.S IS HERE FOR YOU!!! We offer all types of services, from a basic lube, to the full service! S.T.U.D.S.
girlcrazy_420 is offline   Reply With Quote
Old 04-08-2009, 05:33 PM   #2
Looks like the new fuel pump already packed it in. Another reason why a vehicle should be left with a full tank over winter.
