FS: Toyota MR2 parts. Both mk1 and mk2 turbo parts MK1 interior trim - lower rear plastic trim behind seats both sides $20 for both - fuel lines plastic cover in engine bay $10 - dash pieces around gauge cluster including switches $20 stock shift knob $5 seat belt clip with wire [both sides] $10 each 2 plastic coolant tubes with filler caps. $10 each 87-89 side vent $20 87-89 plastic e-brake handle cover $10 engine bay fan $15 window washer reservoir with pump $15 87-89 manual gauge cluster $50 front orange turn signals $10 each fuel pump $25 hood latch with cable and lever $25 cooling fan relay $10 steering wheel plastic covers [front and rear] $15 driver side outside door handle $20 **RARE** door buzzer $.99 buahhaha i dont know who would want this. window crank handles $5 each MK2 stock gen2 fuel rail with 440cc injectors. $100 intercooler pipe support bracket $20 93+ [i think] ignition coil $50 stock turbo metal coolant line $20 brand new spark plug wires $50 usdm ecu [89661-17331] $100 turbo fuel pump $50 walbro fuel pump $100 turbo half shafts [hub ends, both sides] $150 stock intercooler $40 stock throttle body inlet $25 fuel pump relay $40 resealed afm $100 stock cold start injector $25 injecter resistor pack $40 LOTS MORE TO COME. ask if you're interested in anything else |
| All times are GMT -8. The time now is 09:15 AM. |
