Old 06-12-2009, 08:47 PM   #1
lil-trip-bo's Avatar
FS: Toyota MR2 parts. Both mk1 and mk2 turbo parts
MK1
interior trim
- lower rear plastic trim behind seats both sides $20 for both
- fuel lines plastic cover in engine bay $10
- dash pieces around gauge cluster including switches $20
stock shift knob $5
seat belt clip with wire [both sides] $10 each
2 plastic coolant tubes with filler caps. $10 each
87-89 side vent $20
87-89 plastic e-brake handle cover $10
engine bay fan $15
window washer reservoir with pump $15
87-89 manual gauge cluster $50
front orange turn signals $10 each
fuel pump $25
hood latch with cable and lever $25
cooling fan relay $10
steering wheel plastic covers [front and rear] $15
driver side outside door handle $20
**RARE** door buzzer $.99 buahhaha i dont know who would want this.
window crank handles $5 each
MK2
stock gen2 fuel rail with 440cc injectors. $100
intercooler pipe support bracket $20
93+ [i think] ignition coil $50
stock turbo metal coolant line $20
brand new spark plug wires $50
usdm ecu [89661-17331] $100
turbo fuel pump $50
walbro fuel pump $100
turbo half shafts [hub ends, both sides] $150
stock intercooler $40
stock throttle body inlet $25
fuel pump relay $40
resealed afm $100
stock cold start injector $25
injecter resistor pack $40
LOTS MORE TO COME. ask if you're interested in anything else
lil-trip-bo is offline   Reply With Quote
