FS: LS Parts! Dizzy, Head, TBelt, HG, Catch Cans, Valve Covers, Alt, Clutch, SCATRods All prices have been cut in half... Prices are all firm and all items are picked up. OBD2 B18B1 OEM Replacement (RP) Distributor - $140 B18B1/A1 B20 NGK OEM Replacement Ignition Leads - $30 OBD2 Style B18/B20 Valve Cover with Vents - $50 OBD2 Style B18/B20 Powder Coated -12AN Vented Valve Cover - $50 RTFab Catch Can , Four -12AN vents - $80 Moroso Vacuum Breather Canister (Catch Can) 85465 - $70 Two Earl's Fittings -12AN Swivel Fittings - $20 OEM Honda B18B1 Timing Belt BNIB - $50 OEM Replacement Honda B18B1 Timing Belt, Lightly Used - $10 OEM Replacement Honda B18C1 Timing Belt, Lightly Used - $10 OEM Honda B18B1 Headgasket BNIB - $60 OEM Replacement (Valeo) Mint Condition B Series Clutch Disc and Pressure Plate - $40 B18B1 Head, Completely Rebuilt - $160 OBD2 USDM B18 Alternator - $20 Spare Tire from a 99 Hatchback - free SiR Prop Valve for Four Wheel Disc - $20 Kinetic Motorsport Brass 1/4" NPT to -4AN Oil Restrictor - $10 SCAT Forged Connecting Rods for B18A/B18B/B20 BNIB - $340 1995 B18B1 Short Block (see details below) - $50 Hella Horn - $20 B Swap Front Torque Brackets with Mounts - $40 each, $60 both. OBD2 B18B1 OEM Replacement (RP) Distributor - $140 - Has about 6,000kms on it. Minty fresh.. http://i205.photobucket.com/albums/b...e/DSC_7742.jpg B18B1/A1 B20 NGK OEM Replacement Ignition Leads - $30 - Has about 6,000kms on them. Minty fresh. http://i205.photobucket.com/albums/b...e/DSC_7742.jpg OBD2 Style B18/B20 Valve Cover with Vents - $50 - Yes, it will fit B18A's as well. http://i205.photobucket.com/albums/b...d/DSC_2463.jpg http://i205.photobucket.com/albums/b...d/DSC_2469.jpg http://i26.photobucket.com/albums/c118/dar1n/drewvc.jpg http://i205.photobucket.com/albums/b...e/DSC_7737.jpg http://i205.photobucket.com/albums/b...e/DSC_7736.jpg OBD2 Style B18/B20 Powder Coated Valve Cover with -12AN Vents - $50 http://i205.photobucket.com/albums/b...e/DSC_7738.jpg http://i205.photobucket.com/albums/b...e/DSC_7739.jpg RTFab Aluminum Catch Can with 4 -12AN Vents - $80 http://i26.photobucket.com/albums/c1...n/drewcan2.jpg http://i26.photobucket.com/albums/c1...n/drewcan1.jpg http://i205.photobucket.com/albums/b...e/DSC_7751.jpg http://i205.photobucket.com/albums/b...e/DSC_7752.jpg Moroso Vacuum Breather Canister (Catch Can) 85465 - $70 - In excellent condition, just light scratching on it. - All parts are included per the picture below in the Summit Online catalogue - http://www.summitracing.com/parts/MO...5/?image=large http://i205.photobucket.com/albums/b...e/DSC_7749.jpg http://i205.photobucket.com/albums/b...e/DSC_7750.jpg Two Earl's Fittings -12AN Swivel Fittings - $20 - Good condition. http://i205.photobucket.com/albums/b...e/DSC_7745.jpg http://i205.photobucket.com/albums/b...e/DSC_7746.jpg OEM Honda B18B1 Timing Belt BNIB - $50 http://i205.photobucket.com/albums/b...e/DSC_7744.jpg OEM Replacement Honda B18B1 Timing Belt, Lightly Used - $10 - About 3,000kms on it, still like new http://i205.photobucket.com/albums/b...e/DSC_7760.jpg http://i205.photobucket.com/albums/b...e/DSC_7761.jpg OEM Replacement Honda B18C1 Timing Belt, Lightly Used - $10 - About 3,000kms on it, still like new http://i205.photobucket.com/albums/b...e/DSC_7747.jpg http://i205.photobucket.com/albums/b...e/DSC_7748.jpg OEM Honda B18B1 Headgasket BNIB - $60 http://i205.photobucket.com/albums/b...e/DSC_7734.jpg Valeo OEM Replacement B Series Clutch Disc and Pressure Plate - $40 - basically brand new, looks like it was barely used - the clutch disc is for a cable transmission. http://i205.photobucket.com/albums/b...e/DSC_7756.jpg http://i205.photobucket.com/albums/b...e/DSC_7757.jpg http://i205.photobucket.com/albums/b...e/DSC_7758.jpg B18B1 Head, Completely Rebuilt - $160 - includes all parts on the head ... caps, cams, gears, LMAs, springs, retainers, etc etc - doesn't include dizzy or valve cover - will include one of my two valve covers shown above for $200 total - resurfaced, 5 angle valve grind, mild polish, OEM valve guides, OEM valve seals http://i205.photobucket.com/albums/b...e/DSC_7767.jpg #1 Intake http://i205.photobucket.com/albums/b...e/DSC_7769.jpg #2 Intake http://i205.photobucket.com/albums/b...e/DSC_7771.jpg #3 Intake http://i205.photobucket.com/albums/b...e/DSC_7772.jpg #4 Intake http://i205.photobucket.com/albums/b...e/DSC_7773.jpg Top Journals http://i205.photobucket.com/albums/b...e/DSC_7774.jpg #1 Exhaust http://i205.photobucket.com/albums/b...e/DSC_7780.jpg #2 Exhaust http://i205.photobucket.com/albums/b...e/DSC_7781.jpg #3 Exhaust http://i205.photobucket.com/albums/b...e/DSC_7782.jpg #4 Exhaust http://i205.photobucket.com/albums/b...e/DSC_7784.jpg Date Stamp http://i205.photobucket.com/albums/b...e/DSC_7785.jpg Extra Bits all Wrapped up http://i205.photobucket.com/albums/b...e/DSC_7786.jpg Surface http://i205.photobucket.com/albums/b...e/DSC_7787.jpg Cylinder Close Up http://i205.photobucket.com/albums/b...e/DSC_7788.jpg OBD2 USDM B18 Alternator - $20 - Great condition - Low price because of odd plug end from USDM car - If you can find a plug or you need an alternator core, this would a steal - http://ff-squad.com/tech/alternator/...ator.plugs.jpg - http://ff-squad.com/wp/?p=4253 - http://www.honda-tech.com/showthread.php?t=2603806 My alternator http://img178.imageshack.us/img178/3...1762nr5.th.jpg Spare Tire from a 99 Hatchback - free - Never used - Won't fit over my brakes, so just getting rid of it. http://img443.imageshack.us/img443/4...1750ws4.th.jpg SiR Prop Valve for Four Wheel Disc - $20 - Will probably never get around to installing this, who am I kidding http://img244.imageshack.us/img244/9...1767pk5.th.jpg Kinetic Oil Restrictor - $10 - 1/4" NPT to -4AN - Will fit most turbos (doesn't work with my Precision) -http://www.kineticmotorsport.com/products/KINETIC_T_SERIES_OIL_RESTRICTOR-480-24.html http://i205.photobucket.com/albums/b...e/DSC_7741.jpg Scat Forged Connecting Rods for B18A/B18B/B20 BNIB - $340 - still have receipt for $400 plus tax, never used, not even taken out of bag. http://i205.photobucket.com/albums/b...e/DSC_7762.jpg http://i205.photobucket.com/albums/b...e/DSC_7763.jpg http://i205.photobucket.com/albums/b...e/DSC_7764.jpg 1995 B18B1 Short Block - $50 - Includes the following: - Crank, Mains, Oil Pump, Water Pump (new), Tensioner, Timing Belt Covers, Rear Water Pipe, Thermostat Housing, Z10 Crankcase Breather plug... don't think any more but I have to check it - Will likely need 0.25mm bore - Does not include pistons, rods, crankcase breather box, oil pan. http://i205.photobucket.com/albums/b...e/DSC_7789.jpg http://i205.photobucket.com/albums/b...e/DSC_7790.jpg http://i205.photobucket.com/albums/b...DSC_7791-1.jpg http://i205.photobucket.com/albums/b...DSC_7792-1.jpg http://i205.photobucket.com/albums/b...DSC_7793-1.jpg http://i205.photobucket.com/albums/b...DSC_7794-1.jpg http://i205.photobucket.com/albums/b...DSC_7795-1.jpg Parts that come with it: Thermo housing, water pipe, windage tray, alternator brackets, pickup http://i205.photobucket.com/albums/b...e/DSC_7766.jpg Hella Aftermarket Horn - $20 - makes funny noises when you honk it! http://i205.photobucket.com/albums/b...e/DSC_7765.jpg Front Torque Mount Brackets for B Swaps in EG/EK - $40 each $60 for both - both the AC bracket mount side and the tranny mount side - only have the picture of the tranny mount one below, but have both http://i205.photobucket.com/albums/b...e/DSC_7743.jpg |
ttt |
ttt |
bump |
ttt |
| All times are GMT -8. The time now is 10:38 PM. |
