Old 12-15-2009, 06:35 PM   #1
FS: LS Parts! Dizzy, Head, TBelt, HG, Catch Cans, Valve Covers, Alt, Clutch, SCATRods
All prices have been cut in half...
Prices are all firm and all items are picked up.
OBD2 B18B1 OEM Replacement (RP) Distributor - $140
B18B1/A1 B20 NGK OEM Replacement Ignition Leads - $30
OBD2 Style B18/B20 Valve Cover with Vents - $50
OBD2 Style B18/B20 Powder Coated -12AN Vented Valve Cover - $50
RTFab Catch Can , Four -12AN vents - $80
Moroso Vacuum Breather Canister (Catch Can) 85465 - $70
Two Earl's Fittings -12AN Swivel Fittings - $20
OEM Honda B18B1 Timing Belt BNIB - $50
OEM Replacement Honda B18B1 Timing Belt, Lightly Used - $10
OEM Replacement Honda B18C1 Timing Belt, Lightly Used - $10
OEM Honda B18B1 Headgasket BNIB - $60
OEM Replacement (Valeo) Mint Condition B Series Clutch Disc and Pressure Plate - $40
B18B1 Head, Completely Rebuilt - $160
OBD2 USDM B18 Alternator - $20
Spare Tire from a 99 Hatchback - free
SiR Prop Valve for Four Wheel Disc - $20
Kinetic Motorsport Brass 1/4" NPT to -4AN Oil Restrictor - $10
SCAT Forged Connecting Rods for B18A/B18B/B20 BNIB - $340
1995 B18B1 Short Block (see details below) - $50
Hella Horn - $20
B Swap Front Torque Brackets with Mounts - $40 each, $60 both.
- Has about 6,000kms on it. Minty fresh..
- Has about 6,000kms on them. Minty fresh.
- Yes, it will fit B18A's as well.
OBD2 Style B18/B20 Powder Coated Valve Cover with -12AN Vents - $50
RTFab Aluminum Catch Can with 4 -12AN Vents - $80
- In excellent condition, just light scratching on it.
- All parts are included per the picture below in the Summit Online catalogue
- http://www.summitracing.com/parts/MO...5/?image=large
- Good condition.
- About 3,000kms on it, still like new
Valeo OEM Replacement B Series Clutch Disc and Pressure Plate - $40
- basically brand new, looks like it was barely used
- the clutch disc is for a cable transmission.
- includes all parts on the head ... caps, cams, gears, LMAs, springs, retainers, etc etc
- doesn't include dizzy or valve cover
- will include one of my two valve covers shown above for $200 total
- resurfaced, 5 angle valve grind, mild polish, OEM valve guides, OEM valve seals
#1 Intake
#2 Intake
#3 Intake
#4 Intake
Top Journals
#1 Exhaust
#2 Exhaust
#3 Exhaust
#4 Exhaust
Date Stamp
Extra Bits all Wrapped up
Surface
Cylinder Close Up
- Great condition
- Low price because of odd plug end from USDM car
- If you can find a plug or you need an alternator core, this would a steal
- http://ff-squad.com/tech/alternator/...ator.plugs.jpg
- http://ff-squad.com/wp/?p=4253
- http://www.honda-tech.com/showthread.php?t=2603806
My alternator
- Never used
- Won't fit over my brakes, so just getting rid of it.
- Will probably never get around to installing this, who am I kidding
Kinetic Oil Restrictor - $10
- 1/4" NPT to -4AN
- Will fit most turbos (doesn't work with my Precision)
-http://www.kineticmotorsport.com/products/KINETIC_T_SERIES_OIL_RESTRICTOR-480-24.html
Scat Forged Connecting Rods for B18A/B18B/B20 BNIB - $340
- still have receipt for $400 plus tax, never used, not even taken out of bag.
1995 B18B1 Short Block - $50
- Includes the following:
- Crank, Mains, Oil Pump, Water Pump (new), Tensioner, Timing Belt Covers, Rear Water Pipe, Thermostat Housing, Z10 Crankcase Breather plug... don't think any more but I have to check it
- Will likely need 0.25mm bore
- Does not include pistons, rods, crankcase breather box, oil pan.
Parts that come with it: Thermo housing, water pipe, windage tray, alternator brackets, pickup
Hella Aftermarket Horn - $20
- makes funny noises when you honk it!
Front Torque Mount Brackets for B Swaps in EG/EK - $40 each $60 for both
- both the AC bracket mount side and the tranny mount side
- only have the picture of the tranny mount one below, but have both
drewbie is offline   Reply With Quote
Old 12-18-2009, 08:29 PM   #2
ttt
Old 01-04-2010, 09:53 PM   #3
ttt
Old 01-06-2010, 01:09 PM   #4
Old 01-09-2010, 10:58 AM   #5
ttt
