Go Back   REVscene Automotive Forum > Technical Discussion > Manufacturer Tech Forums > Honda / Acura Tech Resources
THIS ADSPACE OPEN FOR ADVERTISEMENT
Old 12-30-2009, 02:42 AM   #1
goo3's Avatar
Failed 49 Times in 32 Posts
01 Prelude power door lock problem
The driver side door lock needs two tries (key or inside power switch) to open/close fully. Each try moves it halfway. When I manually move the switch, it's really stiff.
Anyone know where the problem is? Seems to be ok when the weather is warmer.
goo3 is offline   Reply With Quote
Old 12-30-2009, 08:20 PM   #2
lexluthor09's Avatar
take off the inner door panel and lube all the related lock parts.
lexluthor09 is offline   Reply With Quote
Old 12-30-2009, 09:43 PM   #3
JDMEK9Mod | DogWhisperer
spoon.ek9's Avatar
Failed 108 Times in 68 Posts
^ this.
if you decide you want to replace the part, get OEM. don't cheap out on the aftermarket crap.
IG: @spoon.ek9
Old 01-14-2010, 06:18 PM   #4
your power door lock motor is slowly dying. soon you will need a new one
rocketman is offline   Reply With Quote
Old 01-17-2010, 01:25 PM   #5
pull open the door lube up all the moving lock parts and that will buy you some time on parts replacement
