Old 06-28-2010, 02:54 PM   #1
Gumby's Avatar
Failed 143 Times in 71 Posts
Engine parts that have water inside
What parts of the engine have water inside?
On Saturday, I noticed water dripping to form a small puddle under the engine compartment of my 2005 Honda Pilot. I had just done some highway driving with the AC on. It's possible that it isn't water, but it was clear and non-oily. The dripping eventually stopped. No warning lights or problems with temperatures.
Any ideas guys?
Thanks.
Old 06-28-2010, 04:28 PM   #2
Puck Luck's Avatar
condensation from the a/c. drips out of the drain hole tube from the evaporator box. its normal
Don't open your hood to strangers........ N 'ouvrez pas votre capot à des inconnus
Puck Luck is offline   Reply With Quote
Old 06-28-2010, 07:16 PM   #3
As stated, normal.
If it was coolant and smelled sweet, that's another story.
Old 06-29-2010, 08:47 AM   #4
Gumby's Avatar
Ok thanks for the replies guys - just wanted to make sure it's not the sign of a bigger problem. Moderators, close thread if/when possible.
