-   -   Carbon Fibre hoods/parts (https://www.revscene.net/forums/639949-carbon-fibre-hoods-parts.html)
js 03-13-2011 01:07 PM
Question about carbon fibre hoods/parts. Would like to see if its worth re-clearing.
My car came with a CF hood which didn't look too great because of the clear coat. I had the clear coat refinished once before and it looked good as new.
Few years later the clear coat started going again.....
What causes the clear coat to go bad on the CF hood?
Could it be the heat from the engine bay or is the damage done from the sun?
I want to get my hood refinished once more but fear that the clear coat will get messed up again. What is the best way to take care of carbon fibre parts?
js 03-13-2011 01:17 PM
opps sorry, posted in the wrong thread. Mod can you please move this to Vancouver Automotive Chat.
TheSalesman 03-13-2011 01:30 PM
what kind of hood is that?
I'v had my CF hood for years and it hasn't faded yet...
-EuroRSN- 03-13-2011 02:02 PM
Ask E.LO he re cleared his CF himself and as far as i know its still good. Hopefully he chimes in on this thread.
js 03-13-2011 02:11 PM
Not exactly sure what brand my hood is but my friend has a seibon hood and it appears to have the same effect. Seems to be a common problem on carbon fibre parts.
!e.lo_ 03-13-2011 02:43 PM
You are so far behind my friend lol
I did reclear my hood via spray bombs, looked fine after buffing but did not last.
I'm not sure what the cause is, but I assume it's the type of clear coat and engine heat.
My plan to reclear the hood is, sanding it with 500, 1000, wet sand 1500. Then get it cleared at a shop with proper UV protecting clear. Then high temp black the underside. There's none of that factory insulation stuff on the underside.
-EuroRSN- 03-13-2011 03:09 PM
^ My baddd lol
dangonay 03-13-2011 03:13 PM
Perhaps it's the UV from the sun. Didn't GM use a special additive in the CF bits on the Corvette to prevent UV problems? If I remember it's $60,000 per gallon.
js 03-13-2011 03:38 PM
I don't want to get the hood re-done and come across the same problem. I might just get the hood painted over to match the colour of the car.
TheMatty 03-13-2011 04:09 PM
yup my cf wing needs some tlc too
spoon.ek9 03-13-2011 04:19 PM
i haven't had a problem with my hood but it also doesn't see rain/snow and is garage parked all year long. did u polish your hood with any waxes/sealants after the first re-clear-coating? i would imagine the fading wouldn't happen so quickly with some regular polishing.
Spooling 03-13-2011 08:08 PM
most likely its a compatibility issue.
AWDTurboLuvr 03-13-2011 10:14 PM
Any good recommendations for a shop that can put on a good layer of UV coating on some CF parts??
