Tips & tricks, tech support, home theatre, online gaming, reviews, latest news... |  |
03-14-2011, 09:00 PM
#1 | | I WANT MY 10 YEARS BACK FROM RS.net!
| NAS Hard Drive Write Speed > Read Speed, normal?
Installed a WD 2.0T EARS in my new Synology. Used Cyrstal Mark to test the HD speed, it shows write speed is quicker than read speed. When it was installed in my PC, it shows 118MB/s write, 88MB/s read. What's happening here?
03-14-2011, 09:06 PM
#2 | | I WANT MY 10 YEARS BACK FROM RS.net!
Your PC's NIC's downstream is probably being clogged with pr0n downloads.
Green drives suck for NAS anyway, especially if you're running a RAID configuration.
__________________ Quote:
Originally Posted by Godzira Does anyone know how many to a signature? | .. Quote:
Originally Posted by Brianrietta Not a sebberry post goes by where I don't frown and think to myself "so..?" | |
03-14-2011, 11:08 PM
#3 | | I WANT MY 10 YEARS BACK FROM RS.net!
it's a single-bay NAS, my Green drive fits the spec of it.
and I wish I get 30MB/s of porn download speed LOL. No matter how the NAS connects, the numbers are similar.
03-15-2011, 12:37 AM
#4 | | Snapping away
how come the green's suck in a NAS?
03-15-2011, 01:43 AM
#5 | | My homepage has been set to RS
Failed 73 Times in 39 Posts
[23-07, 02:03] shawn79 i find that at vietnamese place they cut ur hair like they cut grass
[23-07, 02:03] shawn79 do u go to vietnamese places for haircuts | |
03-15-2011, 02:49 AM
#6 | | I WANT MY 10 YEARS BACK FROM RS.net!
Green drive also has LLC problem, the drive spins down after 8 seconds which will wear out faster, I have already disabled it.
03-15-2011, 09:28 AM
#7 | | Diagonally parked in a parallel universe
Failed 3 Times in 2 Posts
I don't know about Synology but QNAP doesn't recommend the use of Green drives in their NAS boxes....
Note5 (WD Caviar Green)
These hard disk drives have passed QNAP lab's initial verification of compatibility. However, because many users have reported unstable experience with these hard disk drives, we do not recommend using these had disk drives with QNAP products. Posted via RS Mobile |
03-15-2011, 07:14 PM
#8 | | Snapping away
Originally Posted by asian_XL Green drive also has LLC problem, the drive spins down after 8 seconds which will wear out faster, I have already disabled it. | it wears out faster because it stops and conserves power ...?
edit: of course, what would we do w/o google:
"In short, the LLC problem is this: the WD 'Green drives' try to reduce the power consumption
by parking their heads after few seconds that there is nothing to read or write.
However, with Linux-based computers (like Synology NAS), disks receive requests even only
to re-read some data every few seconds. What happens in the WD greens is that if they are idle
you can hear a click of the head parking... and then immediately moving again. Every about 8 seconds.
If you repeat this 24h per day, you can imagine that is not healthy for the disk.
And here the WDIDLE3 tool comes to help, by delaying the head parking."
should i be running wdidle3 in a non-NAS setup? when i searched for wdidle3 briefly it shows it as a firmware tool, rather than a dos command toggle.
edit2: just did it using the following instructions: http://www.jzab.de/content/ultimate-...-util-included
- burn the iso or make a bootable iso:
- extract the iso with i.e. winrar.
- http://www.ultimatebootcd.com/customize.html ; scroll to 'Making UBCD memory stick'
- it won't be your T: probably, use the 'list all drives' command to see which one (of 3 on mine when booted)
- upon first boot it said bootmgr missing (probably 'cause i disconnected the other drives when performing this), so go into the BIOS first to re-select the correct boot drive
03-15-2011, 09:49 PM
#9 | | Diagonally parked in a parallel universe
Parking heads that many times a day is not good... Also spinning down and up and down and up will kill a drive faster than leaving it spinning 24x7x365.
When it comes to raid or nas don't cheap out... At least buy regular desktop drives, forget about the green drives. If it's mission critical data then invest in enterprise class drives, although you probably wouldn't do so unless you were running a more expensive / higher performing raid or nas. Posted via RS Mobile |
03-15-2011, 09:50 PM
#10 | | I WANT MY 10 YEARS BACK FROM RS.net!
disabling it makes your drive slightly slightly faster and much more reliable.
03-16-2011, 02:13 PM
#11 | | Got MOD?
Failed 5 Times in 4 Posts
I have 2 WD Greens EARS 2TB running in RAID mirror. No problems. I used WDIDLE3 to set the idle to 5min. rather than disabled.
RAID is about data availability and uptime. NOT a replacement for backups.
03-16-2011, 02:14 PM
#12 | | Snapping away
how come you set it to 5 minutes rather than disabled?
03-16-2011, 03:19 PM
#13 | | Got MOD?
I remember seeing some users had some slowdown problems with it if it was completely disabled so I set it to the max timer of 5min. I think it was in NCIX forums but I can't remember. It's easy to change anyways if needed. These are great drives. Quiet, low power, low heat.
03-16-2011, 03:45 PM
#14 | | I WANT MY 10 YEARS BACK FROM RS.net!
We build and install commercial- and enterprise-grade surveillance DVRs, they have to handle sustained data transfer 24x7... we use the Western Digital Caviar Black drives almost exclusively, and they've been great - fast, and reliable. You pay about a 50% premium over the Green drives, but it's worth it.
03-16-2011, 04:21 PM
#15 | | Got MOD?
Yup. It definitely depends on what your needs are. Mine are storage and accessibility over speed. I also have 2 WD Black 2TB drives in RAID. They're awesome but overkill for my needs.
03-16-2011, 05:08 PM
#16 | | Snapping away
Originally Posted by !MiKrofT I remember seeing some users had some slowdown problems with it if it was completely disabled so I set it to the max timer of 5min. I think it was in NCIX forums but I can't remember. It's easy to change anyways if needed. These are great drives. Quiet, low power, low heat. | here's the thread: http://forums.ncix.com/forums/?mode=...d=0#msg2278208
i'll set it back to 300 seconds. still curious as to why. thnx though.
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -8. The time now is 08:28 PM. |
