-   Maintenance, Engine & Driveline Tech (https://www.revscene.net/forums/maintenance-engine-driveline-tech_190/)
-   -   using wrong pcv valve? problem? (https://www.revscene.net/forums/648944-using-wrong-pcv-valve-problem.html)
Holeshot 07-02-2011 03:42 PM
i got a pcv valve for a b18b when i should have gotten one for a b18c, will it affect anything? the car is a 98 integra gsr. it does have oil burning issues.
Qmx323 07-02-2011 04:54 PM
ur fine, rockauto says that the PCV valves are the same.
Also the same PCV used in a couple toyotas too lol
what brand is the one u have?
Holeshot 07-02-2011 05:21 PM
it a fram one. fram saids that there are different. so does rockauto.
Qmx323 07-02-2011 11:43 PM
click on the part number. cross compatibility will pop up.
FV309 which is for a B18B1 can be used on GSRs B18C1
They seem to be interchangeable
Holeshot 07-05-2011 11:43 AM
i picked up the "correct" one. no difference in the valve but i did notice that the hose was kinked somehow and that why i was burning oil.
