Old 07-02-2011, 03:42 PM   #1
Failed 5 Times in 1 Post
using wrong pcv valve? problem?
i got a pcv valve for a b18b when i should have gotten one for a b18c, will it affect anything? the car is a 98 integra gsr. it does have oil burning issues.
Holeshot is offline   Reply With Quote
Old 07-02-2011, 04:54 PM   #2
Qmx323's Avatar
Failed 221 Times in 82 Posts
ur fine, rockauto says that the PCV valves are the same.
Also the same PCV used in a couple toyotas too lol
what brand is the one u have?
Old 07-02-2011, 05:21 PM   #3
it a fram one. fram saids that there are different. so does rockauto.
Old 07-02-2011, 11:43 PM   #4
Qmx323's Avatar
click on the part number. cross compatibility will pop up.
FV309 which is for a B18B1 can be used on GSRs B18C1
They seem to be interchangeable
Old 07-05-2011, 11:43 AM   #5
i picked up the "correct" one. no difference in the valve but i did notice that the hose was kinked somehow and that why i was burning oil.
