Go Back   REVscene Automotive Forum > Technical Discussion > Autobody, Lighting, & Structural Tech
Autobody, Lighting, & Structural Tech This forum is brought to you by RPM Electronics in Burnaby.
Discussion about modifying your auotomotive lighting, retrofits, auto body, share projects, ideas, etc.
Old 03-05-2012, 02:16 PM   #1
m86
NEWBIE ACCOUNT!
Civic Driver Side Door Lock Problem
Hi everyone, so I've got a question about my Honda Civic 2003 Si. Ever since I've got the car, no one can seem to fix the lock issue I have on the driver side door. It's tough to explain, so I took pictures of it:
The lock isn't all the way in when it's locked, and sticks out too much when it's unlocked. If I push down on the driver side lock, it locks both doors. Does anyone know anything? I'm hoping to try and fix it myself, I don't want anyone else touching it anymore.
m86 is offline   Reply With Quote
Old 03-07-2012, 12:16 AM   #2
Puck Luck's Avatar
pushing down on the driver's lock knob will lock all doors.Thats normal.
The lock knob is screwed on to the end of a threaded rod. Just take the door panel off and twist the knob down a couple turns
Don't open your hood to strangers........ N 'ouvrez pas votre capot à des inconnus
Puck Luck is offline   Reply With Quote
