Go Back   REVscene Automotive Forum > Technical Discussion > Manufacturer Tech Forums > Honda / Acura Tech Resources
THIS ADSPACE OPEN FOR ADVERTISEMENT
Old 12-05-2012, 05:07 PM   #1
roastpuff's Avatar
Failed 48 Times in 28 Posts
Weird electrical/battery problem?
So my mom's Acura CSX (2008) wouldn't start up one day - took a look under the hood, and the positive battery terminal was covered in blue foam. Battery was leaking, I guess - so I jump started it and took it to the dealer. They recommended a battery replacement due to age so we did it. This was on Saturday.
The car was fine the next few days, but this morning my mom told me that she couldn't start the car - it wouldn't turn over at all, and seemed to lose electrical power when she turned the key to the "ON" position. I had already left for school so I couldn't test it myself. When I got home and tried to start the car, it cranked up perfectly on the first twist. Weird!
My guess is that the cold/wet has something to do with it? It wasn't that cold this morning though and the battery is brand new, so there should not have been any problems....
Any other suggestions? I will be swapping cars with Mom tomorrow and keeping my jumper pack in the trunk in case something happens. If it does happen again, I will bring the car to the dealer and have them look at it - obviously, replacing the battery didn't solve the problem.
Old 12-05-2012, 05:22 PM   #2
SumAznGuy's Avatar
Failed 128 Times in 71 Posts
Blue stuff on the battery terminals is normal battery corrosion. All you need is a toothbrush, water, and baking soda to offset the acidity.
How to Clean Car Battery Terminals | Cleaning Guides
Check to see if the battery terminals are on tight. IIRC, factory Honda battery post are sometimes a tad smaller than the clamps. So if they are not properly tightened, you may not have a good connection between the car and battery.
(11-0-0) Buy/Sell rating
Christine
Shitvic
Pull Out Towing
Old 12-05-2012, 05:40 PM   #3
bluejays's Avatar
Failed 84 Times in 12 Posts
New battery shouldnt be doing that, make sure its tight and if it continues maybe test your alternator
Current:
10 Evolution GSR (Summer)
'01 Sentra (Daily)
Past:'06 Civic Si
bluejays is offline   Reply With Quote
Old 12-09-2012, 01:06 AM   #4
NOOB, Not Quite a Regular!
Make sure you have good clean connections
BMAKL is offline   Reply With Quote
Old 12-26-2012, 05:30 PM   #5
I am Hook'd on RS
could be alternator or dizzy
EastVan is offline   Reply With Quote
