Toyota 2zz-ge engine parts I have most parts from a 2zz engine. It spun a rod bearing. Cylinder head with cams, sensors, oil switches intake manifold with throttle body block - one of the cylinders is a bit scuffed up but you can't feel it, when the engine was running the cylinder held compression fine. crank - the 4th journal is damaged. con rods and pistons - one rod is damaged water pump tensioner valve cover stock flywheel stock clutch stock exhaust manifold and heat shield probably other parts that i've forgotten to list, send me a message and I might have it. Parts are currently located near 16th and cambie. |
| All times are GMT -8. The time now is 11:21 AM. |
