Old 12-15-2012, 03:10 PM   #1
Failed 77 Times in 9 Posts
Toyota 2zz-ge engine parts
I have most parts from a 2zz engine. It spun a rod bearing.
Cylinder head with cams, sensors, oil switches
intake manifold with throttle body
block - one of the cylinders is a bit scuffed up but you can't feel it, when the engine was running the cylinder held compression fine.
crank - the 4th journal is damaged.
con rods and pistons - one rod is damaged
water pump
tensioner
valve cover
stock flywheel
stock clutch
stock exhaust manifold and heat shield
probably other parts that i've forgotten to list, send me a message and I might have it.
Parts are currently located near 16th and cambie.
dutch is offline   Reply With Quote
