THIS ADSPACE OPEN FOR ADVERTISEMENT | |
11-01-2013, 03:58 PM
#1 | 14 dolla balla aint got nothing on me!
| 1997 Integra overheating @ idle problem, Help!
Hey guys,
So I've been driving down to clark and back home. And along the way home, noticed my integra was overheating at idle.
This happened before due to a ripped hose and bad clamp.
Problem has resurrected, I managed to get home so I can check out what was wrong.
After checking it out, turns out I can't find any faulty or ripped hoses. But noticed my coolant reservoir was half empty from full. Help?
Also noticed this happened after I parked my integra. |
11-01-2013, 09:36 PM
#2 | Head of HR....have a seat on that couch
Have you checked the rad for cracks?
__________________ feedback Originally posted by v.b. can we stop, my pussy hurts... Originally posted by asian_XL fliptuner, I am gonna grab ur dick and pee in your face, then rub shit all over my face...:lol Originally posted by Fei-Ji haha i can taste the cum in my mouth Originally posted by FastAnna when I was 13 I wanted to be a video hoe so bad RSUV #7 |
11-01-2013, 10:35 PM
#3 | 14 dolla balla aint got nothing on me!
No I haven't but will keep that in mind for tomorrow morning. Thanks
11-02-2013, 02:08 PM
#4 | RS controls my life!
that looks like oil on the ground. by any chance, your car an automatic?
__________________ Don't open your hood to strangers........ N 'ouvrez pas votre capot à des inconnus |
11-07-2013, 03:01 AM
#5 | My homepage has been set to RS
this happened to me before. I had a crack so I had to get it fixed or else it would keep overheating. I was driving a rsx though. Another way of keeping it cool is by blasting your heat high. It will slowly come down as u watch the gauge. Hope this helps. Posted via RS Mobile |
11-07-2013, 11:55 AM
#6 | Where's my RS Christmas Lobster?!
check for leaks then test your thermostat to see if it is opening. if thats all good try a rad flush (flush ita few times).
if its still overheating after that you could have a bad head gasket allowing exhaust gasses to build up in your coolant...
02-13-2014, 05:27 PM
#7 | Rs has made me the woman i am today!
How long ago did the broken/ripped hose happened? Did you properly bleed the cooling system after the repairs?
02-14-2014, 07:18 AM
#8 | I told him no, what y'all do?
Originally Posted by ICE BOY Have you checked the rad for cracks? | Quote:
Originally Posted by Prolowtone check for leaks then test your thermostat to see if it is opening. | had 2 heating problems you described with my previous car and these were the causes.
__________________ Feedback http://www.revscene.net/forums/showthread.php?t=611711 Quote: Greenstoner 1 rat shit ruins the whole congee originalhypa You cannot live the life of a whore and expect a monument to your chastity | Quote:
02-24-2014, 03:10 PM
#9 | I LIKE JDM!!
I had a similar issue but with my 97 Honda Prelude, it would start to overheat at idle. After poking around I noticed that the radiator fan motor had died. I installed a new OEM fan motor and everything was back to normal. Perhaps you have something similar? I dunno, just a thought.
02-25-2014, 02:54 PM
#10 | Witness protection
the coolant overflow reservoir is not the best indicator of how much coolant there is in your engine, unlesss it's bone dry or it's overflowing with boiling coolant, of which neither is what you are experiencing.
when you blew your coolant hose, how was the engine refilled with coolant? was it properly bled of air?
with a the engine cold, did you check the coolant level from taking off the radiator cap and looking inside? how is the condition of the radiator cap itself?
how does your coolant look inside the radiator? ie. normal color, or is it like brown porridge? are there bubbles coming out while the engine is running?
have you had any issues with the thermostat? is the cooling fan coming on at engine temp?
i can't tell much from that picture why there is oil on the ground. have you looked for any obvious signs of oil leakage? what is your oil level like?
__________________ "The guy in the CR-V meanwhile, he'll give you a haughty glare. He's responsibly trying to lessen his impact, but there you go lumbering past him with your loud V8, flouting the new reality. You may as well go do some donuts in a strawberry patch and slalom through a litter of kittens." Dan Frio, Automotive Editor, Edmunds
02-25-2014, 02:59 PM
#11 | Zionism gets my shell hard and slimy
if you cant see signs of a leak the first place i would look is at your thermostat, if you notice a difference in temperature in the hoses coming off your rad "top and bottom" then there is a good chance your thermostat is stuck closed
next would be rad fan, you said it was an idle thing so you might wanna check to see that your fan turned on
02-25-2014, 09:01 PM
#12 | RS has made me the bitter person i am today!
actually, there should be some difference in temp between the upper and lower rad hose. remember, the rad is supposed to lower the temp of the incoming coolant
Gold is the money of kings;
-Norm Franz
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -8. The time now is 01:55 AM. |
