Old 01-03-2014, 03:34 PM   #1
2 Wheelin' Mod
Jas29's Avatar
Failed 18 Times in 10 Posts
2006 Hyundai Accent P0450 Engine Code help fixing
Hyundai P0450 OBD/DLC Error Code - Evaporative Emission System Pressure Sensor/Switch
Causes
Possible causes of OBD code P0450
- The EVAP control system pressure sensor circuit is open or shorted - Rubber hose to EVAP control system pressure is clogged, vent, kinked, disconnected or improper connection. - EVAP control system pressure sensor may be faulty - EVAP The Error code is generally activated on detection of the following conditions: - An improper voltage signal from EVAP control system pressure sensor is sent to ECM.
Possible Solutions
- Replaced EVAP Control System Pressure Sensor
Where is the Pressure sensor located even
Jas29 is offline   Reply With Quote
Old 01-03-2014, 05:45 PM   #2
Circle Stick Square Mod
!Tigger's Avatar
Failed 21 Times in 13 Posts
gas tank beside the charcoal canister
!Tigger is offline   Reply With Quote
