-   -   Rogers LTE problem (or iphone 5s problem?) (https://www.revscene.net/forums/693073-rogers-lte-problem-iphone-5s-problem.html)
Ulic Qel-Droma 02-25-2014 12:56 AM
I have a bell iphone 5s. got it unlocked, and im with rogers. everything works but if i enable LTE, it says "LTE" on the top left but data doesnt connect to anything. as if data was turned off.
wtf?
FN-2199 02-25-2014 01:52 AM
A common problem with Rogers that I've experienced for years, but who knows, it might be your phone. Even when I'm on LTE and my phone tells me I have 3 bars, it struggles to load Google.
StylinRed 02-25-2014 03:36 AM
maybe you have to manually enter rogers data address into the phone?
i remember needing to do that with my unlocked phone before because the phone wasn't reading/entering the info from the sim card correctly
!Aznboi128 02-25-2014 06:33 AM
there's no such thing anymore
make sure you have the following:
your phone is a canadian phone with canadian lte bands
your plan is lte enabled
your sim is lte capable
FerrariEnzo 02-25-2014 07:07 AM
If its data issues, could be related to APN settings
akira112 02-25-2014 10:33 AM
lteinternet.apn
Mr.HappySilp 02-25-2014 10:33 AM
+1 have to do that to my unlock international version of Z1.
StylinRed 02-26-2014 03:31 AM
Originally Posted by akira112 (Post 8423853)
lteinternet.apn
yeah that's what i meant
vafanculo 02-26-2014 08:34 AM
I don't think you can change APN settings on apple. With androids though, you almost always have to.
Reset your network settings on the phone. Does data work with LTE off?
!Aznboi128 02-26-2014 12:35 PM
APN settings is automatic read off the sim, go to Settings -> General -> reset -> reset network settings. Give that a shot, if that doesn't work head over to the Apple Store and see if they can give you a hand.
vafanculo 02-26-2014 03:50 PM
One more thing..if reset network settings doesn't work, factory reset the phone and reactivate it with the Rogers Sim in the phone (could solve APN issue if you simply put the rogers Sim in the phone after it was unlocked.
bcrdukes 02-26-2014 03:57 PM
Spoke to Ulic earlier today. A new SIM solved the problem.
