Old 01-30-2015, 11:41 AM   #1
gomcse2002's Avatar
Failed 25 Times in 14 Posts
Will this help speed up charging my Android phone ?
Hi there
If I get a SCOSCHE USBC242M 12 Watt USB Car Charger with 2.1A ports, and connect my Android phone to the 2.1A port, will this speed up the charging time ?
Please kindly advise.
http://www.amazon.com/gp/product/B00...29&camp=211189
REVScene Feedback Ratings
gomcse2002 is offline   Reply With Quote
Old 01-30-2015, 11:47 AM   #2
FerrariEnzo's Avatar
2.1a ports should be faster then 1a ports... shorter cables also provide faster charging like 3ft vs 6ft...
if your phone supports quick charge, can take up to 5a ports also...
overcharging your phone on a higher port is also bad for battery life, i.e. overnight...
My Buy&Sell Feedback, Thanx
Old 01-30-2015, 11:48 AM   #3
gomcse2002's Avatar
I see. thanks.
Old 01-30-2015, 12:14 PM   #4
I am grateful grapefruit
gars's Avatar
Failed 83 Times in 11 Posts
It depends on your phone and the charging cable. The distance isn't the deciding factor for the cable - it's also the gauge (thickness) of the wire.
Some older phones might only ever draw a max of 500mA, which is what a standard USB port on a computer will provide, so a 2.1A charger won't do anything. (usually standard USB cables have 28AWG - smaller is better)
You're probably looking at 24AWG or thicker if you want to try a high amperage charger.
I recently bought this set and it's working great for me (21AWG)
http://www.amazon.ca/gp/product/B00M...ilpage_o03_s00
