Old 04-14-2016, 01:13 PM   #1
gomcse2002's Avatar
Failed 25 Times in 14 Posts
X-Star 27" DP2710LED 2560x1440 PLS 120hz LED LCD Monitor
Up for sale is a used X-Star DP2710LED 27" monitor from Korea. Comes with HDMI cable and original power cord. There are only 4 buttons on the monitor, volume + (up), Volume - (Down), Brightness (Up) and Brightness (Down)
The only flaws I realized recently is that all the buttons are not working but the monitor is working and the current brightness is good enough for day to day use. That's why I sell for so cheap. Asking for $ 150.00 firm. No return and No refund.
Graphic Card Compatibility
- It uses Bypass type board. Compatibility issue with Graphic card and Mainboards may occur. Please check the compatibility before purchase.
Compatible :
GT440 / GT450 / GT460 / GTX550TI / GTX560 / GTX560TI / GTX570 / GTX580
HD5450 / HD5550 / HD5670 / HD5830 / HD6570 / HD6750 / HD6770 / HD6870 / HD6950 / HD6970 / HD6990
NOT compatible :
HD5570 / HD5750 / HD5770 / HD5850 / HD5870 / HD5970
Recommended graphic cards
-NVIDIA: GTX460 or more than 1GB memory, with Dual Linked DVI-D port.
-ATI: HD6850 or more than 1GB memory, with Dual Linked DVI-D port.
Dual Monitor configuration recommended
-GTX580 or HD6970. The GPU should have 2 Dual linked DVI port.
-Please use DVI-D port only. Cannot be used with DVI-I or DVI-S.
Brand : X-STAR
Model : DP2710 LED
Type : 27Inch (68.5cm)
Panel : SAMSUNG PLS
Screen Size : 596.74 x 335.66 mm
Resolution : WQHD 2560 x 1440
Contrast : 1000 : 1 (DCR 50000:1)
Luminosity : 300 cd/㎡
Pixel Pitch : 0.233 mm
Viewing Angle : 178˚ (Up / Down / Left / Right)
Color Display : 16.7 MP
Back-light : LED
Input : DVI (Dual Link) / Audio (In / Out) / Power
Power : 45 W
Standby Power : 0.5 W
Size (Stand) : 646 x 462.96 x 57 mm
Size (Stand X) : 646 x 399.8 x 57 mm
<CONTENTS>
Monitor
DVI-D (Dual Link) Cable
AU Power Cable
Audio Cable
REVScene Feedback Ratings
gomcse2002 is offline   Reply With Quote
