THIS ADSPACE OPEN FOR ADVERTISEMENT |  |
07-24-2018, 01:29 PM
#1 | | I am Hook'd on RS
Failed 25 Times in 3 Posts
| EG6 Parts/Replacement: Oil Pan
Hello all,
I'm in the middle of fixing up my Civic and I need a new oil pan.
Wondering what the community considers a strong brand.
I'm working my way from the back to the front and I have very little knowledge on cars and aftermarket parts and what's good quality vs not - so hopefully you guys can help me along the way.
I haven't pulled out the current pan, so I'm not sure what's in there. Could be a modified stock pan - not sure.
Some details - I have a B18 84mm block with a B16 head/vtec w/ Garrett T3/T4 turbo and the car is lowered.
Thoughts here?
Help is much appreciated!
07-24-2018, 02:22 PM
#2 | | I contribute to threads in the offtopic forum
Failed 73 Times in 28 Posts
What’s wrong with the current pan?
07-24-2018, 02:44 PM
#3 | | I am Hook'd on RS
It's leaking oil out of the pan in several places. It looks like they may have modified the pan.
Also have a turbo oil leak  may or may not have something to with the pan.
Also oil gauge isn't reading properly perhaps.
07-25-2018, 10:44 PM
#4 | | Need to Shave n Shower, but I CANT STOP POSTING ON RS
moroso has always been a big brand in aftermarket oil pans.
__________________ Until the lions have their own historians, the history of the hunt will always glorify the hunter. |
07-26-2018, 08:51 AM
#5 | | I am Hook'd on RS
Glad to hear! It's pretty much the only one I could find online.
Looks like mopac in Langley is a dealer. $400 for the pan tho ouch! LOL...
Cheers!
07-26-2018, 12:44 PM
#6 | | I contribute to threads in the offtopic forum
Can’t just replace the pan gasket for like $20 and 15min?
Ran factory pan on 5 turbo’d Honda’s
07-26-2018, 01:03 PM
#7 | | I am Hook'd on RS
Originally Posted by cdizzle_996 Can’t just replace the pan gasket for like $20 and 15min?
Ran factory pan on 5 turbo’d Honda’s | I've taking it apart tomorrow morning. I'll post some photos of the progress and what's going on (haven't removed the pan yet). Could just be some lines are broken. Ultimately, I have an oil leak. Doesn't appear to be engine. Turbo and pan are affected though.
When I turn the car on, a bunch oil spews out the turbo and there's noticeable leaks in the pan area too.
I believe it's a stock pan I got right now.
07-26-2018, 01:56 PM
#8 | | WUB WUB WUB WUB WUB
Failed 202 Times in 90 Posts
Most of the time when oil pans leak, it's the gasket/sealant and not the pan itself
__________________ FEEDBACK (9-0-0) SPOTTED Quote:
Originally Posted by slowguy fuck you hipster | Quote:
Originally Posted by trollguy then fuck you hipster akinari | Quote: |
07-26-2018, 03:34 PM
#9 | | I am Hook'd on RS
I hope it's this easy!
I'll post progress
07-27-2018, 12:00 PM
#10 | | I am Hook'd on RS
So... I embarrassed to say that oil leak was a...
*Drumroll*
Loose oil filter....
I cleaned everything underneath, inspected all spots... Touched the oil filter and it was loose. Was able to give it about 4 spins with my fingers loose.
So everything seems tip top.
Just need to fix the cable on driver's side e-brake and clean her up and she'll be ready for the Vancouver streets!
Need new battery and glue as well. The rubber around the windshield is coming off.
Thanks for all the suggestions!
Glad it was a series of false alarms.
07-27-2018, 12:21 PM
#11 | | Head of HR....have a seat on that couch
I have Civic batteries.
Use urethane for the trim but mask off the area first. That shit is a bitch to get off and can make a mess.
__________________ feedback Originally posted by v.b. can we stop, my pussy hurts... Originally posted by asian_XL fliptuner, I am gonna grab ur dick and pee in your face, then rub shit all over my face...:lol Originally posted by Fei-Ji haha i can taste the cum in my mouth Originally posted by FastAnna when I was 13 I wanted to be a video hoe so bad RSUV #7 |
07-27-2018, 12:46 PM
#12 | | I am Hook'd on RS
What does this mean?
I have a optima high performance agm battery. Bought July 16 2017. I have receipt. Was going to see if I can exchange.
Should I be using a different battery?
07-27-2018, 12:54 PM
#13 | | Head of HR....have a seat on that couch
If they'll replace it, why not?
Wouldn't be my first choice, otherwise.
07-27-2018, 12:57 PM
#14 | | I am Hook'd on RS
What battery should I use? I feel like I've been having battery issues since I've owned this thing.
07-27-2018, 01:03 PM
#15 | | Head of HR....have a seat on that couch
Optima quality has gone downhill and is pretty hit or miss.
Depends what you're doing with the car, if weight matters.
07-27-2018, 01:44 PM
#16 | | I am Hook'd on RS
Weight may matter one day.. when I'm less people like Louis says... So I don't think weight is an issue at the moment.
08-15-2018, 12:42 PM
#17 | | I am Hook'd on RS
Hey guys - so car SEEMS to be running strong.
However, as soon as I turn key, my oil pressure gauge goes past 100.
I've got a part lined up for me at Lordco to replace. But I'm concerned it may not be the gauge. It's like 120bones for this thing.
This is I believe what's in the car and what I've got on hold at Lordco. https://www.autometer.com/2-oil-pres...ltra-lite.html
Thoughts?
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -8. The time now is 06:34 AM. |
