Go Back   REVscene Automotive Forum > Technical Discussion > Suspension, Brakes , Wheels & Tires Tech
Suspension, Brakes , Wheels & Tires Tech THIS SPACE OPEN FOR ADVERTISEMENT. YOU SHOULD BE ADVERTISING HERE!
Suspension components, brakes, Wheels and Tires. All things related to how your car handles...
Old 08-29-2009, 02:53 PM   #1
keitaro's Avatar
Failed 10 Times in 5 Posts
Brake Reservoir Cap Parts Break down help
So i am building a brake pressure bleeder out of a garden spray bottle. I just bought a used brake cap and took it apart.
The car that i am trying to bleed is a 2005 Honda civic. The following image below is the break down of the cap (bought one from a junker)
What is the rubber part on the right for? Also what is the purpose of the white part?
Also in the reservoir there is a screen assy. is it removable?
Thanks
keitaro is offline   Reply With Quote
Old 08-29-2009, 04:22 PM   #2
wacko604's Avatar
The rubber part is the seal. The white part is just part of the cap, and the screen in the resovoir is removeable.
wacko604 is offline   Reply With Quote
Old 08-31-2009, 06:31 PM   #3
NOOB, Not Quite a Regular!
Anything is removable if you want it to be.
BoostLover is offline   Reply With Quote
Old 09-01-2009, 08:40 AM   #4
keitaro's Avatar
thanks guys!
I got it modified, just got to do the finishing touches!
Old 09-01-2009, 04:23 PM   #5
Puck Luck's Avatar
Thanks
post a pic after you're done building the contraption, I'm curious to see
Don't open your hood to strangers........ N 'ouvrez pas votre capot à des inconnus
Puck Luck is offline   Reply With Quote
