Old 02-19-2011, 05:43 AM   #1
geeknerd's Avatar
Failed 397 Times in 91 Posts
Comp build thread teach me and help me choose parts too.
Case: CM 690 II Basic
PSU: Corsair 650W TX
HDD: WD 500GB cblack
CPU: Intel Core I7-960
Mobo: x58 Sabertooth
VID: Asus engtx 460 1gb
RAM: XMS3 3x2 GB
FAN: 120mm Coolermaster
CD: Lite-on iHas224-06
Monitor: VE247H
Cooling: Corsair h50
geeknerd is offline   Reply With Quote
Old 02-19-2011, 06:28 AM   #2
Oh goodie, 5 posts already!
Failed 2 Times in 1 Post
The 920 is an OEM product and is effectively end of life. The 950s are more or less end of life now, too, being replaced by 960s. For a case, the Antec 300 isn't bad, but it isn't great, either. My personal favorite would be the Lancool K62. Remember that your case can be one of the things you keep through several builds. Something in the area of 850-1000W for a PSU would last you for several upgrades and would be fine for SLI or Crossfire for higher end cards. The AX850 or something similar world work nicely.
krajee is offline   Reply With Quote
Old 02-19-2011, 09:53 AM   #3
Guest
Failed 22 Times in 5 Posts
if you are not in a hurry, i suggest waiting for the new sandy bridge motherboards to come out and then build the comp. there is a grea performance increase for a lower price.
Vulcan300 is offline   Reply With Quote
Old 02-19-2011, 10:53 AM   #4
Failed 882 Times in 422 Posts
don't waste $ on SLi/CF
if you are planning to go watercooling in the future pick a CPU with tons of OC overhead.
Old 02-19-2011, 11:16 AM   #5
Got MOD?
!MiKrofT's Avatar
Failed 5 Times in 4 Posts
Currently SandyBridge motherboards have a SATA problem on the 3.0gbps ports. The issue is that it MAY corrupt data over time. However I don't think any OEM has been able to reproduce the issue. New boards probably won't be out for at least another month or 2. I have one of the affected boards and ASUS is going to replace them for free. If you can't wait that long you can still build a system but using the SATA 6.0Gbps ports until the replacements are out.
[NS] Niteshadow.ca
'95 Integra RS R.I.P.
My Feedback (50-0-0)
Old 03-01-2011, 02:39 PM   #6
geeknerd's Avatar
updated
Old 03-01-2011, 03:56 PM   #7
ddr
Snapping away
ddr's Avatar
SSD (Intel/Corsair) + terabytes of storage
should totally do this at memoryexpress right now for the 10% off, but check shopbot as well
flickr
ddr is offline   Reply With Quote
Old 03-01-2011, 04:08 PM   #8
Mr.HappySilp's Avatar
Failed 929 Times in 340 Posts
I would suggest another Video card like GTX 570
Old 03-01-2011, 06:56 PM   #9
geeknerd's Avatar
i wish i could do this with the current 10% off but im limited in funds and ill do this in half a year - a year.. by then the price will prbbly drop more than 10% anyways hopefully..
if i buy 570 my wallet will only be used to carry my DL lol.
anyways, i went ahead and bought what i have written on there.
basically this is what i do right?
mount mobo, mount hdd, mount cd drive, mount fans, mount psu, put in cpu, stick on cooler, connect all the wiring, done?
Old 03-01-2011, 07:02 PM   #10
Qmx323's Avatar
Failed 221 Times in 82 Posts
after "mount mobo" it doesnt matter what order
and use zip ties to bunch together wiring to keep airflow maximized.
Old 03-01-2011, 07:22 PM   #11
Sandybridge is a disappointment, they claim new chip won't come out until April. Some companies like ECS are now offering a PCI-E Raid card to new buyers.
Old 03-01-2011, 07:26 PM   #12
Hmm well for that price range of video card I would pick
http://www.ncix.com/products/?sku=55...=MSI/MicroStar
http://www.ncix.com/products/?sku=54...SI%2FMicroStar
I currently have the MSI GTX 460 Cyclone and is great!
