Old 03-13-2011, 01:07 PM   #1
js
js's Avatar
Failed 3 Times in 1 Post
Carbon Fibre hoods/parts
Question about carbon fibre hoods/parts. Would like to see if its worth re-clearing.
My car came with a CF hood which didn't look too great because of the clear coat. I had the clear coat refinished once before and it looked good as new.
Few years later the clear coat started going again.....
What causes the clear coat to go bad on the CF hood?
Could it be the heat from the engine bay or is the damage done from the sun?
I want to get my hood refinished once more but fear that the clear coat will get messed up again. What is the best way to take care of carbon fibre parts?
js is offline   Reply With Quote
Old 03-13-2011, 01:17 PM   #2
js
js's Avatar
opps sorry, posted in the wrong thread. Mod can you please move this to Vancouver Automotive Chat.
Old 03-13-2011, 01:30 PM   #3
TheSalesman's Avatar
Failed 26 Times in 9 Posts
what kind of hood is that?
I'v had my CF hood for years and it hasn't faded yet...
TheSalesman is offline   Reply With Quote
Old 03-13-2011, 02:02 PM   #4
Kick' In' Duh' Bass
-EuroRSN-'s Avatar
Failed 434 Times in 65 Posts
Ask E.LO he re cleared his CF himself and as far as i know its still good. Hopefully he chimes in on this thread.
Flickr
The DC5 Member's Journal
> 2005 Acura TSX ASPEC <
> 2003 Acura RSX-S <
> 1994 Acura Intergra LS <
> 1994 Honda Civic SI <
> 1991 Acura Integra GS < ( RIP )
Old 03-13-2011, 02:11 PM   #5
js
js's Avatar
Not exactly sure what brand my hood is but my friend has a seibon hood and it appears to have the same effect. Seems to be a common problem on carbon fibre parts.
Old 03-13-2011, 02:43 PM   #6
Editor
!e.lo_'s Avatar
Failed 56 Times in 19 Posts
You are so far behind my friend lol
I did reclear my hood via spray bombs, looked fine after buffing but did not last.
I'm not sure what the cause is, but I assume it's the type of clear coat and engine heat.
My plan to reclear the hood is, sanding it with 500, 1000, wet sand 1500. Then get it cleared at a shop with proper UV protecting clear. Then high temp black the underside. There's none of that factory insulation stuff on the underside.
!e.lo_ is offline   Reply With Quote
Old 03-13-2011, 03:09 PM   #7
Kick' In' Duh' Bass
-EuroRSN-'s Avatar
^ My baddd lol
Flickr
> 2003 Acura RSX-S <
Old 03-13-2011, 03:13 PM   #8
dangonay's Avatar
Failed 418 Times in 151 Posts
Perhaps it's the UV from the sun. Didn't GM use a special additive in the CF bits on the Corvette to prevent UV problems? If I remember it's $60,000 per gallon.
dangonay is offline   Reply With Quote
Old 03-13-2011, 03:38 PM   #9
js
js's Avatar
I don't want to get the hood re-done and come across the same problem. I might just get the hood painted over to match the colour of the car.
Old 03-13-2011, 04:09 PM   #10
TheMatty's Avatar
Failed 30 Times in 8 Posts
yup my cf wing needs some tlc too
2003 Mitsubishi Lancer Evolution VIII
2012 Volkswagen Passat TDI
TheMatty is offline   Reply With Quote
Old 03-13-2011, 04:19 PM   #11
JDMEK9Mod | DogWhisperer
spoon.ek9's Avatar
Failed 108 Times in 68 Posts
i haven't had a problem with my hood but it also doesn't see rain/snow and is garage parked all year long. did u polish your hood with any waxes/sealants after the first re-clear-coating? i would imagine the fading wouldn't happen so quickly with some regular polishing.
IG: @spoon.ek9
Old 03-13-2011, 08:08 PM   #12
Guest
Spooling's Avatar
Failed 125 Times in 13 Posts
most likely its a compatibility issue.
Spooling is offline   Reply With Quote
Old 03-13-2011, 10:14 PM   #13
AWDTurboLuvr's Avatar
Any good recommendations for a shop that can put on a good layer of UV coating on some CF parts??
"Happiness lies in the joy of achievement and the thrill of creative effort"
AWDTurboLuvr is offline   Reply With Quote
