Go Back   REVscene Automotive Forum > Technical Discussion > Advanced Forced Induction & N/A Engine Tuning
Advanced Forced Induction & N/A Engine Tuning This forum is brought to you by Racing Greed in Port Coquitlam.
Supercharger vs Turbocharger vs NA? Hondata vs Megasquirt? 94oct vs 87oct? Through technical discussion, let's find out what will the best option for you...
Old 06-21-2011, 01:47 AM   #1
Failed 7 Times in 1 Post
would a smaller oil restrictor help this problem?
right now i am running a 0.065" oil restrictor that came with my turbo.
oil feed is a -4AN.
oil return is a -10AN, as short as i can make it and goes only downhill. maybe a small section that is horizontal.
engine oil pressure is 80~90 psi above 3500 rpm.
i was told there was blue smoke coming out from the exhaust when the engine was under load.
after a hard run, i can also see smoke coming from the turbo, and that smoke contains oil. the engine bay area around the turbo has a film of oil from this smoke.
i believe oil was seeping out the exhaust side. i have yet to take out the intake piping to check for oil in the pipe.
the turbo was brand new from Precision when i installed it.
it is a ball bearing turbo.
would using a 0.035" restrictor help?
or should i troubleshoot else where?
would high crank case pressure cause the blue smoke too?
Bath Tussue is offline   Reply With Quote
Old 06-21-2011, 12:32 PM   #2
Yep, improving crank case breathing it what I would look at first.
1983 Volvo 240 Wagon. S80 T6 Swap.
541whp/467wtq, SpeedPro Dynojet
Originally Posted by dizzystar View Post
I am better than everyone, you, your brothers, sisters, fathers, moms, even your fucking dogs. I can drive all drivetrain platforms and all types of industrial machinery, and I got a fucking nuclear sub, yeah thats right, a fucking nuclear sub.
fuck you, and all your shit.
this is revscene in it's entirety. /thread.
Captain Bondo is offline   Reply With Quote
Old 07-03-2011, 10:07 AM   #3
sdubfid's Avatar
Failed 26 Times in 10 Posts
I would run a smaller restrictor. I have the -4an .030/.035 one from kinetic on my car since october. My friend has run them on 3-4 bb turbos with no issues.
They/them
69 Camaro LS/T56
sdubfid is offline   Reply With Quote
Old 07-03-2011, 08:32 PM   #4
i had a chance to take off the intake piping.
there were tons of oil in there too.
but i was not sure if the oil is from the oil vapour that came out the exhaust side.
i am currently working on making vents on the valve cover and making a 1/32" oil restrictor.
Old 07-08-2011, 08:48 PM   #5
update: problem fixed.
i did several things at the same time, so i don't know which one is the real solution.
first, i made a 1/32" restrictor. turns out the restrictor originally in the turbo is actually a 0.035", so i didn't use the one i made.
i also took out all the intake pipes and cleaned out all the oil in there. every piece of pipe was covered in oil. the bottom of the intercooler had a huge puddle in there.
i also rerouted the oil return so there are less horizontal travel. and from that, i was able to cut 2 inches off the length of the hose.
taking out the oil return caused a lot of engine oil to leak out, so i also did an oil change with 2L of Motul 300V and 3 L of 8100.
the result is that there were no blue smoke at all during the 15 minute sessions on the track.
but after the first hard session, an insane amount of smoke was coming from under the hood. the oil that leaked before got soaked byt he turbo blanket, and those oil were burning off. after that, the car is just fine with the exception of melted waste hoses
Old 07-13-2011, 07:31 PM   #6
Huh? Almost no oil should leak out when you remove the oil return, it should be above the oil level in the pan. If oil dumps out when you pull the return line something is wrong.
Old 10-26-2011, 03:58 PM   #7
NEWBIE ACCOUNT!
sounds like the restrictor fixed things. try going back to the old one to confirm.
benr is offline   Reply With Quote
