Old 03-25-2015, 02:25 PM   #1
ajax's Avatar
Failed 84 Times in 48 Posts
Help: Battery, Alternator, or Connection Issue?
I've been having bit of a puzzling issue with my G35 coupe (2005, 6mt).
This started Monday after I pulled over to gas up. When I got back into my car to start it all lights came on as usual but when I turned the key to actually start the engine all that happened was it clicked once than all electrical power was lost.
A few minutes later a couple lights would come back in (but very dim) and the key remote can unlock/lock the car. I got a jump from someone and the car started up right away. I drove home (Vancouver - Coquitlam) fine.
The next morning, the same issue happened again. Turn key to start, click sound, all electric power lost. Jumping the car again started it immediately. After I got to work, I turned off my car and then started it again with no problems.
Leaving work yesterday I had no problems starting and made it home fine. When I got home I turned the car off but the issue happened again when I tried starting it.
I required another jump start today morning, but this afternoon the car started up perfectly fine after being parked for a few hours at work (I tried about 4-5 times in a row: start, run for a minute, turn off).
The battery is still fairly new (installed September last year) and there are no aftermarket stereo accessories.
A similar issue was happening last year but stopped until this week when the new battery was installed.
Anyone have any idea on what could be causing it?
Edit: Had no issues yesterday after getting a jump in the morning. Started up fine after work and when I got home. I installed a new battery just in case and will wait and see if the issue persists.
ajax is offline   Reply With Quote
Old 03-25-2015, 02:49 PM   #2
Bender Unit's Avatar
Failed 41 Times in 16 Posts
Sound like your Alternator won't charge.
My FeedBacks
Bender Unit is offline   Reply With Quote
Old 03-25-2015, 03:03 PM   #3
ajax's Avatar
If it's an alternator problem, I should have the electronics dying when I drive though right?
I'll try to get my hands on a voltmeter and check tonight though.
Old 03-27-2015, 01:59 AM   #4
Failed 11 Times in 5 Posts
check with a voltmeter you should see your voltage sitting between 14.5-15.5 approx. a dead cell on a battery can also cause the same concern.
dn53 is offline   Reply With Quote
Old 03-27-2015, 05:05 PM   #5
snails's Avatar
Failed 253 Times in 80 Posts
very easy way to test alt vs battery.. start the car.. now take the negative off a battery.. if the car dies, its the alternator. if the car runs its the battery
a voltmeter would be best to test if there is a connection issue somewhere
Originally Posted by smoothie. View Post
It doesn't matter what size you are, if all you do is masturbate.
Old 03-27-2015, 05:11 PM   #6
Seems like a bad connection somewhere.
Have you checked the wires and clamps going to the battery?
Old 03-27-2015, 05:32 PM   #7
Double check that your battery terminals are properly tight and clamping the posts. I had an issue once where the post was a touch too small, so when things heated up the clamp expanded and didn't make good contact.
Old 03-28-2015, 12:05 AM   #8
cunninglinguist's Avatar
Failed 11 Times in 4 Posts
I second the bad connection at the terminals diagnosis.
cunninglinguist is offline   Reply With Quote
Old 03-28-2015, 03:37 PM   #9
NOOB, Not Quite a Regular!
Genzlinger's Avatar
definitely check for lose/bad connections first leading to the battery and then proceed to alternator & battery test.
Genzlinger is offline   Reply With Quote
Old 03-28-2015, 03:52 PM   #10
Soundy's Avatar
Incorrect - everything will continue running off the battery.
Old 03-28-2015, 04:17 PM   #11
Eventually, the lights will dim and engine will run like shit, then die.
I say it's a connection problem cause it's intermittent and fires up with a boost (more amperage to overcome a bad connection).
If the alt was bad, it would eventually drain the batt and when he went to boost it, it would start but as soon as you disconnect the cables, the engine would die.
If the batt was bad, it wouldn't start sometimes - it would only start with a jump every time.
Old 03-28-2015, 04:50 PM   #12
Soundy's Avatar
True, but it won't all just die instantly. Lights will probably be a bit dimmer since they're only running at 12V instead of ~14.5, but other than that, the thing would keep running for a while.
+1
Old 03-28-2015, 10:36 PM   #13
SpeedFactor's Avatar
Without a load tester it's really hard to say. Right now we are all just guessing.
SpeedFactor is offline   Reply With Quote
Old 03-28-2015, 11:19 PM   #14
Soundy's Avatar
Sure, but most are reasonably educated guesses based on experience and the described symptoms.
Old 03-29-2015, 01:51 AM   #15
Depends on the car, with no alt my car will limp along at best, any attempt to go above a fraction of throttle and it bogs.
Old 04-02-2015, 03:53 PM   #16
Survey says..........????????
Old 04-16-2015, 08:07 AM   #17
Great68's Avatar
Failed 188 Times in 103 Posts
This is also a very easy way to potentially damage the electronics in your car.
1968 Mustang Coupe
2008.5 Mazdaspeed 3
1997 GMC Sonoma ZR2
2014 F150 5.0L XTR 4x4
A vehicle for all occasions
Old 04-22-2015, 11:20 PM   #18
RS Lurker, I don't post!
I think you should ask the repair shop, Battery, Alternator, or Connection
qiangasgoo is offline   Reply With Quote
Old 04-23-2015, 11:44 AM   #19
If your alternator was pooched you wouldnt be able to drive from Van to Coq on a dead battery. So Id be inclined to think battery or connection. DO NOT ATTEMPT TO RUN YOUR ENGINE AND DISCONNECT YOUR BATTERY TO SEE IF THE ALTERNATOR IS FINE. That will fuck up a good alternator in a hurry leading you to think you need an alternator when you more often then not didnt.
