Still got that massive gasoline stain though. |
I've used liquid dish soap with scrubbing to get out oil before, whatever you're using let it sit and work a bit before washing it off. You might need to do a few passes to get it all out too. |
how about the ones on TV , "30 seconds" thing or "CLR" |
If it's bad I'll usually soak with undiluted degreaser, and scrub with a very stiff brush/steel brush. But earlier this year I bought myself a 13HP pressure washer with a 14" whirl-a-way surface cleaner and it makes quick work of everything. |
| All times are GMT -8. The time now is 05:05 AM. |
